Manual Chapter : Integrating PQC on the client-side
Applies To:
Show Versions Show Versions
Manual Chapter
About PQC
PQC (Post-Quantum Cryptography) is a new method of cryptography that develops algorithms resistant to quantum computer attacks. These algorithms rely on mathematical problems that remain hard to solve even for quantum computers.
Popular encryption methods, such as RSA, ECC (Elliptic Curve Cryptography), and Diffie-Hellman, are designed around solving very hard mathematical problems. These problems are almost impossible for traditional computers to solve within a reasonable time. However, with the emergence of
Quantum Computers
, the situation has changed. Quantum Computers can solve these problems in a fraction of the time using algorithms like
Shor’s algorithm
, making current encryption methods
obsolete and insecure
One of the serious threats today is
“Harvest Now, Decrypt Later”
attacks. This means that even if your data seems secure now, it might be vulnerable in the future. To address this, PQC ensures that even if someone steals encrypted data, they won’t be able to decrypt it – now or in the future.
X25519KYBER768 Key Exchange:
To reduce the risks of the new age, BIG-IP now supports the Hybrid X25519_Kyber768 key exchange in TLS 1.3 on the client-side, improving security against future quantum-based threats. This new DH curve protects encrypted data from "Harvest Now, Decrypt Later" attacks by integrating post-quantum cryptographic resilience. You can now implement quantum-safe encryption while maintaining compatibility with existing security protocols. This implementation of PQC algorithms is designed to make it easier for organizations to test, integrate, and prototype quantum-safe cryptographic systems
X25519MLKEM768 Key Exchange:
BIG-IP now supports the Hybrid X25519_MLKEM768, an NIST approved algorithm.
X25519MLKEM768
is a
hybrid key exchange mechanism
that combines X25519 and MLKEM768. Together, they protect encryption key exchanges against current threats and those expected in a future with quantum computing.
Important
PQC implementation is compatible only with the TLS 1.3 protocol
Note
: Support for X25519KYBER768 will be deprecated soon. It is recommended to transition to X25519MLKEM768.
Configuration X25519KYBER768 through GUI
Configure X25519KYBER768 through Cipher Rules
Follow the below steps, to create a Cipher Rule:
  1. On the
    Main
    tab, expand
    Local Traffic
    . Go to
    Ciphers
    and select
    Rules
  2. Click the
    Create
    button.
  3. In the
    Name
    field, type a name for the new cipher rule.
  4. Select any of the suites from
    Cipher Suites
    field's provided list. Use "ALL" or "DEFAULT" to list all the available suites. for example, DEFAULT
  5. In the DH Groups entry, add "X25519KYBER768" for PQC ciphers or you can use "DEFAULT:" to list the available groups. Example: "DEFAULT:X25519KYBER768".
  6. For the
    Signature Algorithms
    field, select an algorithm. Example, DEFAULT.
  7. Click the
    Finished
    button.
Configure X25519KYBER768 through Cipher Group
Use the cipher rules to create cipher groups, follow the below steps:
  1. On the
    Main
    tab, expand
    Local Traffic
  2. Go to
    Ciphers
    and select
    Groups
    .Click the
    Create
    button.
  3. Provide the details in the
    General
    section. Select the rule created in the above step from
    Group Creation > Available Rules
  4. Add the created rule to "Allow the following list" or "Restrict the Allowed list to the following" in the
    Group Details
    section.
  5. All the other details
    such as
    DH Group, Signature Algorithms,
    and
    Cipher Suites,
    will be reflected in the
    Group Audit
    section as per the selected rule.
  6. Click the
    Finished
    button.
Configure X25519KYBER768 through Client-SSL profile
To add the cipher group to a Client SSL profile, follow the below steps:
  1. Go to
    Profile > SSL > Client
  2. Select any existing profile or create a new one, and set the
    Configuration
    value to
    Advanced
  3. Go to
    Ciphers,
    and select the
    Cipher Group
    radio button. Select the created group to enable the created Ciphers group for the client SSL profile.
Configuration X25519KYBER768 through TMSH
Use the below commands to create cipher rules
  1. SSH into the BIG-IP system and log in with admin credentials. Type
    tmsh
    to enter the Traffic Management Shell.
  2. Create the ltm cipher rule using the following commands:
    root@(localhost)(cfg-sync Standalone)(Active)(/Common)(tmos)# create ltm cipher rule TMSH_PQC cipher DEFAULT dh-groups DEFAULT:X25519KYBER768 signature-algorithms DEFAULT
  3. To list or view the basic details of the created cipher rule use the below command:
    root@(localhost)(cfg-sync Standalone)(Active)(/Common)(tmos)# list ltm cipher rule TMSH_PQC ltm cipher rule TMSH_PQC { cipher DEFAULT dh-groups DEFAULT:X25519KYBER768 signature-algorithms DEFAULT }
  4. To view the complete details of the created cipher rule use the below command:
    root@(localhost)(cfg-sync Standalone)(Active)(/Common)(tmos)# show ltm cipher rule TMSH_PQC -------------------- Ltm::Cipher::Rule -------------------- Name TMSH_PQC Cipher Suites ECDHE-RSA-AES128-GCM-SHA256/TLS1.2:ECDHE-RSA-AES128-GCM-SHA256/DTLS1.2:ECDHE-RSA-AES128-CBC-SHA/TLS1.0:ECDHE-RSA-AES128-CBC-SHA/TLS1.1:ECDHE-RSA-AES128-CBC-SHA/DTLS1.0:ECDHE-RSA-AES128-CBC-SHA/TLS1.2:ECDHE-RSA-AES128-CBC-SHA/DTLS1.2:ECDHE-RSA-AES128-SHA256/TLS1.2:ECDHE-RSA-AES128-SHA256/DTLS1.2:ECDHE-RSA-AES256-GCM-SHA384/TLS1.2:ECDHE-RSA-AES256-GCM-SHA384/DTLS1.2:ECDHE-RSA-AES256-CBC-SHA/TLS1.0:ECDHE-RSA-AES256-CBC-SHA/TLS1.1:ECDHE-RSA-AES256-CBC-SHA/DTLS1.0:ECDHE-RSA-AES256-CBC-SHA/TLS1.2:ECDHE-RSA-AES256-CBC-SHA/DTLS1.2:ECDHE-RSA-AES256-SHA384/TLS1.2:ECDHE-RSA-AES256-SHA384/DTLS1.2:AES128-GCM-SHA256/TLS1.2:AES128-GCM-SHA256/DTLS1.2:AES128-SHA/TLS1.0:AES128-SHA/TLS1.1:AES128-SHA/TLS1.2:AES128-SHA/DTLS1.2:AES128-SHA/DTLS1.0:AES128-SHA256/TLS1.2:AES128-SHA256/DTLS1.2:AES256-GCM-SHA384/TLS1.2:AES256-GCM-SHA384/DTLS1.2:AES256-SHA/TLS1.0:AES256-SHA/TLS1.1:AES256-SHA/TLS1.2:AES256-SHA/DTLS1.2:AES256-SHA/DTLS1.0:AES256-SHA256/TLS1.2:AES256-SHA256/DTLS1.2:CAMELLIA128-SHA/TLS1.0:CAMELLIA128-SHA/TLS1.1:CAMELLIA128-SHA/TLS1.2:CAMELLIA128-SHA/DTLS1.2:CAMELLIA256-SHA/TLS1.0:CAMELLIA256-SHA/TLS1.1:CAMELLIA256-SHA/TLS1.2:CAMELLIA256-SHA/DTLS1.2:ECDHE-ECDSA-AES128-GCM-SHA256/TLS1.2:ECDHE-ECDSA-AES128-GCM-SHA256/DTLS1.2:ECDHE-ECDSA-AES128-CCM/TLS1.2:ECDHE-ECDSA-AES128-CCM/DTLS1.2:ECDHE-ECDSA-AES128-CCM8/TLS1.2:ECDHE-ECDSA-AES128-CCM8/DTLS1.2:ECDHE-ECDSA-AES128-SHA/TLS1.0:ECDHE-ECDSA-AES128-SHA/TLS1.1:ECDHE-ECDSA-AES128-SHA/TLS1.2:ECDHE-ECDSA-AES128-SHA/DTLS1.2:ECDHE-ECDSA-AES128-SHA256/TLS1.2:ECDHE-ECDSA-AES128-SHA256/DTLS1.2:ECDHE-ECDSA-AES256-GCM-SHA384/TLS1.2:ECDHE-ECDSA-AES256-GCM-SHA384/DTLS1.2:ECDHE-ECDSA-AES256-CCM/TLS1.2:ECDHE-ECDSA-AES256-CCM/DTLS1.2:ECDHE-ECDSA-AES256-CCM8/TLS1.2:ECDHE-ECDSA-AES256-CCM8/DTLS1.2:ECDHE-ECDSA-AES256-SHA/TLS1.0:ECDHE-ECDSA-AES256-SHA/TLS1.1:ECDHE-ECDSA-AES256-SHA/TLS1.2:ECDHE-ECDSA-AES256-SHA/DTLS1.2:ECDHE-ECDSA-AES256-SHA384/TLS1.2:ECDHE-ECDSA-AES256-SHA384/DTLS1.2:DHE-RSA-AES128-GCM-SHA256/TLS1.2:DHE-RSA-AES128-GCM-SHA256/DTLS1.2:DHE-RSA-AES128-SHA/TLS1.0:DHE-RSA-AES128-SHA/TLS1.1:DHE-RSA-AES128-SHA/TLS1.2:DHE-RSA-AES128-SHA/DTLS1.2:DHE-RSA-AES128-SHA/DTLS1.0:DHE-RSA-AES128-SHA256/TLS1.2:DHE-RSA-AES128-SHA256/DTLS1.2:DHE-RSA-AES256-GCM-SHA384/TLS1.2:DHE-RSA-AES256-GCM-SHA384/DTLS1.2:DHE-RSA-AES256-SHA/TLS1.0:DHE-RSA-AES256-SHA/TLS1.1:DHE-RSA-AES256-SHA/TLS1.2:DHE-RSA-AES256-SHA/DTLS1.2:DHE-RSA-AES256-SHA/DTLS1.0:DHE-RSA-AES256-SHA256/TLS1.2:DHE-RSA-AES256-SHA256/DTLS1.2:DHE-RSA-CAMELLIA128-SHA/TLS1.0:DHE-RSA-CAMELLIA128-SHA/TLS1.1:DHE-RSA-CAMELLIA128-SHA/TLS1.2:DHE-RSA-CAMELLIA128-SHA/DTLS1.2:DHE-RSA-CAMELLIA256-SHA/TLS1.0:DHE-RSA-CAMELLIA256-SHA/TLS1.1:DHE-RSA-CAMELLIA256-SHA/TLS1.2:DHE-RSA-CAMELLIA256-SHA/DTLS1.2:TLS13-AES128-GCM-SHA256/TLS1.3:TLS13-AES256-GCM-SHA384/TLS1.3 DH-Groups DEFAULT:X25519KYBER768 Signature Algorithms DEFAULT
    tmsh
  2. Create the ltm cipher group using the following commands:
    root@(localhost)(cfg-sync Standalone)(Active)(/Common)(tmos)# create ltm cipher group TMSH_PQC allow add { TMSH_PQC }
  3. To list or view the basic details of the created cipher group use the below command:
    root@(localhost)(cfg-sync Standalone)(Active)(/Common)(tmos)# list ltm cipher group TMSH_PQC ltm cipher group TMSH_PQC { allow { TMSH_PQC { } } }
    root@(localhost)(cfg-sync Standalone)(Active)(/Common)(tmos)# show ltm cipher group TMSH_PQC --------------------------- Ltm::Cipher::Group --------------------------- Name TMSH_PQC Cipher Result ECDHE-RSA-AES128-GCM-SHA256/TLS1.2:ECDHE-RSA-AES128-GCM-SHA256/DTLS1.2:ECDHE-RSA-AES128-CBC-SHA/TLS1.0:ECDHE-RSA-AES128-CBC-SHA/TLS1.1:ECDHE-RSA-AES128-CBC-SHA/DTLS1.0:ECDHE-RSA-AES128-CBC-SHA/TLS1.2:ECDHE-RSA-AES128-CBC-SHA/DTLS1.2:ECDHE-RSA-AES128-SHA256/TLS1.2:ECDHE-RSA-AES128-SHA256/DTLS1.2:ECDHE-RSA-AES256-GCM-SHA384/TLS1.2:ECDHE-RSA-AES256-GCM-SHA384/DTLS1.2:ECDHE-RSA-AES256-CBC-SHA/TLS1.0:ECDHE-RSA-AES256-CBC-SHA/TLS1.1:ECDHE-RSA-AES256-CBC-SHA/DTLS1.0:ECDHE-RSA-AES256-CBC-SHA/TLS1.2:ECDHE-RSA-AES256-CBC-SHA/DTLS1.2:ECDHE-RSA-AES256-SHA384/TLS1.2:ECDHE-RSA-AES256-SHA384/DTLS1.2:AES128-GCM-SHA256/TLS1.2:AES128-GCM-SHA256/DTLS1.2:AES128-SHA/TLS1.0:AES128-SHA/TLS1.1:AES128-SHA/TLS1.2:AES128-SHA/DTLS1.2:AES128-SHA/DTLS1.0:AES128-SHA256/TLS1.2:AES128-SHA256/DTLS1.2:AES256-GCM-SHA384/TLS1.2:AES256-GCM-SHA384/DTLS1.2:AES256-SHA/TLS1.0:AES256-SHA/TLS1.1:AES256-SHA/TLS1.2:AES256-SHA/DTLS1.2:AES256-SHA/DTLS1.0:AES256-SHA256/TLS1.2:AES256-SHA256/DTLS1.2:CAMELLIA128-SHA/TLS1.0:CAMELLIA128-SHA/TLS1.1:CAMELLIA128-SHA/TLS1.2:CAMELLIA128-SHA/DTLS1.2:CAMELLIA256-SHA/TLS1.0:CAMELLIA256-SHA/TLS1.1:CAMELLIA256-SHA/TLS1.2:CAMELLIA256-SHA/DTLS1.2:ECDHE-ECDSA-AES128-GCM-SHA256/TLS1.2:ECDHE-ECDSA-AES128-GCM-SHA256/DTLS1.2:ECDHE-ECDSA-AES128-CCM/TLS1.2:ECDHE-ECDSA-AES128-CCM/DTLS1.2:ECDHE-ECDSA-AES128-CCM8/TLS1.2:ECDHE-ECDSA-AES128-CCM8/DTLS1.2:ECDHE-ECDSA-AES128-SHA/TLS1.0:ECDHE-ECDSA-AES128-SHA/TLS1.1:ECDHE-ECDSA-AES128-SHA/TLS1.2:ECDHE-ECDSA-AES128-SHA/DTLS1.2:ECDHE-ECDSA-AES128-SHA256/TLS1.2:ECDHE-ECDSA-AES128-SHA256/DTLS1.2:ECDHE-ECDSA-AES256-GCM-SHA384/TLS1.2:ECDHE-ECDSA-AES256-GCM-SHA384/DTLS1.2:ECDHE-ECDSA-AES256-CCM/TLS1.2:ECDHE-ECDSA-AES256-CCM/DTLS1.2:ECDHE-ECDSA-AES256-CCM8/TLS1.2:ECDHE-ECDSA-AES256-CCM8/DTLS1.2:ECDHE-ECDSA-AES256-SHA/TLS1.0:ECDHE-ECDSA-AES256-SHA/TLS1.1:ECDHE-ECDSA-AES256-SHA/TLS1.2:ECDHE-ECDSA-AES256-SHA/DTLS1.2:ECDHE-ECDSA-AES256-SHA384/TLS1.2:ECDHE-ECDSA-AES256-SHA384/DTLS1.2:DHE-RSA-AES128-GCM-SHA256/TLS1.2:DHE-RSA-AES128-GCM-SHA256/DTLS1.2:DHE-RSA-AES128-SHA/TLS1.0:DHE-RSA-AES128-SHA/TLS1.1:DHE-RSA-AES128-SHA/TLS1.2:DHE-RSA-AES128-SHA/DTLS1.2:DHE-RSA-AES128-SHA/DTLS1.0:DHE-RSA-AES128-SHA256/TLS1.2:DHE-RSA-AES128-SHA256/DTLS1.2:DHE-RSA-AES256-GCM-SHA384/TLS1.2:DHE-RSA-AES256-GCM-SHA384/DTLS1.2:DHE-RSA-AES256-SHA/TLS1.0:DHE-RSA-AES256-SHA/TLS1.1:DHE-RSA-AES256-SHA/TLS1.2:DHE-RSA-AES256-SHA/DTLS1.2:DHE-RSA-AES256-SHA/DTLS1.0:DHE-RSA-AES256-SHA256/TLS1.2:DHE-RSA-AES256-SHA256/DTLS1.2:DHE-RSA-CAMELLIA128-SHA/TLS1.0:DHE-RSA-CAMELLIA128-SHA/TLS1.1:DHE-RSA-CAMELLIA128-SHA/TLS1.2:DHE-RSA-CAMELLIA128-SHA/DTLS1.2:DHE-RSA-CAMELLIA256-SHA/TLS1.0:DHE-RSA-CAMELLIA256-SHA/TLS1.1:DHE-RSA-CAMELLIA256-SHA/TLS1.2:DHE-RSA-CAMELLIA256-SHA/DTLS1.2:TLS13-AES128-GCM-SHA256/TLS1.3:TLS13-AES256-GCM-SHA384/TLS1.3 DH-Groups Result P256:X25519:P384:FFDHE2048:FFDHE3072:FFDHE4096:X25519KYBER768 Signature Algorithms Result RSA-PKCS1-SHA256:RSA-PSS-SHA256:ECDSA-SHA256:RSA-PKCS1-SHA384:RSA-PSS-SHA384:ECDSA-SHA384:RSA-PKCS1-SHA512:RSA-PSS-SHA512:ECDSA-SHA512 root@(localhost)(cfg-sync Standalone)(Active)(/Common)(tmos)#
Configure X25519KYBER768 through Client-SSL Profile
Follow the below commands to add the cipher group to a Client SSL profile
    tmsh
  2. Create the Client-SSL profile using the following command:
    root@(localhost)(cfg-sync Standalone)(Active)(/Common)(tmos)# create ltm profile client-ssl TMSH_PQC cipher-group TMSH_PQC options { dont-insert-empty-fragments } ciphers none
  3. To list or view the basic details of the created ltm client-ssl profile use the below command:
    root@(localhost)(cfg-sync Standalone)(Active)(/Common)(tmos)# list ltm profile client-ssl TMSH_PQC ltm profile client-ssl TMSH_PQC { aapp-service none cert-key-chain { default_0 { cert default.crt key default.key } } cipher-group pqc ciphers none defaults-from clientssl inherit-ca-certkeychain true inherit-certkeychain false mode enabled options { dont-insert-empty-fragments } }
Configuration X25519MLKEM768 through GUI
Configure X25519MLKEM768 through Cipher Rules
Configure X25519MLKEM768 through Cipher RulesFollow the below steps, to create a Cipher Rule:
  1. On the
    Main
    tab, expand
    Local Traffic
    . Go to
    Ciphers
    and select
    Rules
  2. Click the
    Create
    button.
  3. In the
    Name
    Cipher Suites
  5. In the DH Groups entry, add "X25519MLKEM768" for PQC ciphers or you can use "DEFAULT:" to list the available groups. Example: "DEFAULT:X25519MLKEM768".
  6. For the
  7. Click the
    Finished
    button.
Configure X25519MLKEM768 through Cipher Group
  1. On the
    Main
    tab, expand
    Local Traffic
  2. Go to
    Ciphers
    and select
    Groups
    .Click the
    Create
    button.
    General
    Group Details
    section.
    such as
    and
    Cipher Suites,
    Group Audit
  6. Click the
    Finished
    button.
Configure X25519MLKEM768 through Client-SSL profile
Configure X25519MLKEM768 through Client-SSL profileTo add the cipher group to a Client SSL profile, follow the below steps:
  1. Go to
    Configuration
    value to
    Advanced
  3. Go to
    Ciphers,
    and select the
    Cipher Group
Configuration X25519MLKEM768 through TMSH
Configure X25519MLKEM768 through Cipher RulesUse the below commands to create cipher rules
    tmsh
    root@(localhost)(pid-6084)(cfg-sync Standalone)(Active)(/Common)(tmos)# create ltm cipher rule TMSH_PQC cipher DEFAULT dh-groups DEFAULT:X25519MLKEM768 signature-algorithms DEFAULT
    root@(localhost)(pid-6084)(cfg-sync Standalone)(Active)(/Common)(tmos)# list ltm cipher rule TMSH_PQC ltm cipher rule TMSH_PQC { cipher DEFAULT dh-groups DEFAULT:X25519MLKEM768 signature-algorithms DEFAULT }
    root@(localhost)(pid-6084)(cfg-sync Standalone)(Active)(/Common)(tmos)# show ltm cipher rule TMSH_PQC -------------------- Ltm::Cipher::Rule -------------------- Name TMSH_PQC Cipher Suites ECDHE-RSA-AES128-GCM-SHA256/TLS1.2:ECDHE-RSA-AES128-GCM-SHA256/DTLS1.2:ECDHE-RSA-AES128-CBC-SHA/TLS1.0:ECDHE-RSA-AES128-CBC-SHA/TLS1.1:ECDHE-RSA-AES128-CBC-SHA/DTLS1.0:ECDHE-RSA-AES128-CBC-SHA/TLS1.2:ECDHE-RSA-AES128-CBC-SHA/DTLS1.2:ECDHE-RSA-AES128-SHA256/TLS1.2:ECDHE-RSA-AES128-SHA256/DTLS1.2:ECDHE-RSA-AES256-GCM-SHA384/TLS1.2:ECDHE-RSA-AES256-GCM-SHA384/DTLS1.2:ECDHE-RSA-AES256-CBC-SHA/TLS1.0:ECDHE-RSA-AES256-CBC-SHA/TLS1.1:ECDHE-RSA-AES256-CBC-SHA/DTLS1.0:ECDHE-RSA-AES256-CBC-SHA/TLS1.2:ECDHE-RSA-AES256-CBC-SHA/DTLS1.2:ECDHE-RSA-AES256-SHA384/TLS1.2:ECDHE-RSA-AES256-SHA384/DTLS1.2:AES128-GCM-SHA256/TLS1.2:AES128-GCM-SHA256/DTLS1.2:AES128-SHA/TLS1.0:AES128-SHA/TLS1.1:AES128-SHA/TLS1.2:AES128-SHA/DTLS1.2:AES128-SHA/DTLS1.0:AES128-SHA256/TLS1.2:AES128-SHA256/DTLS1.2:AES256-GCM-SHA384/TLS1.2:AES256-GCM-SHA384/DTLS1.2:AES256-SHA/TLS1.0:AES256-SHA/TLS1.1:AES256-SHA/TLS1.2:AES256-SHA/DTLS1.2:AES256-SHA/DTLS1.0:AES256-SHA256/TLS1.2:AES256-SHA256/DTLS1.2:CAMELLIA128-SHA/TLS1.0:CAMELLIA128-SHA/TLS1.1:CAMELLIA128-SHA/TLS1.2:CAMELLIA128-SHA/DTLS1.2:CAMELLIA256-SHA/TLS1.0:CAMELLIA256-SHA/TLS1.1:CAMELLIA256-SHA/TLS1.2:CAMELLIA256-SHA/DTLS1.2:ECDHE-ECDSA-AES128-GCM-SHA256/TLS1.2:ECDHE-ECDSA-AES128-GCM-SHA256/DTLS1.2:ECDHE-ECDSA-AES128-CCM/TLS1.2:ECDHE-ECDSA-AES128-CCM/DTLS1.2:ECDHE-ECDSA-AES128-CCM8/TLS1.2:ECDHE-ECDSA-AES128-CCM8/DTLS1.2:ECDHE-ECDSA-AES128-SHA/TLS1.0:ECDHE-ECDSA-AES128-SHA/TLS1.1:ECDHE-ECDSA-AES128-SHA/TLS1.2:ECDHE-ECDSA-AES128-SHA/DTLS1.2:ECDHE-ECDSA-AES128-SHA256/TLS1.2:ECDHE-ECDSA-AES128-SHA256/DTLS1.2:ECDHE-ECDSA-AES256-GCM-SHA384/TLS1.2:ECDHE-ECDSA-AES256-GCM-SHA384/DTLS1.2:ECDHE-ECDSA-AES256-CCM/TLS1.2:ECDHE-ECDSA-AES256-CCM/DTLS1.2:ECDHE-ECDSA-AES256-CCM8/TLS1.2:ECDHE-ECDSA-AES256-CCM8/DTLS1.2:ECDHE-ECDSA-AES256-SHA/TLS1.0:ECDHE-ECDSA-AES256-SHA/TLS1.1:ECDHE-ECDSA-AES256-SHA/TLS1.2:ECDHE-ECDSA-AES256-SHA/DTLS1.2:ECDHE-ECDSA-AES256-SHA384/TLS1.2:ECDHE-ECDSA-AES256-SHA384/DTLS1.2:DHE-RSA-AES128-GCM-SHA256/TLS1.2:DHE-RSA-AES128-GCM-SHA256/DTLS1.2:DHE-RSA-AES128-SHA/TLS1.0:DHE-RSA-AES128-SHA/TLS1.1:DHE-RSA-AES128-SHA/TLS1.2:DHE-RSA-AES128-SHA/DTLS1.2:DHE-RSA-AES128-SHA/DTLS1.0:DHE-RSA-AES128-SHA256/TLS1.2:DHE-RSA-AES128-SHA256/DTLS1.2:DHE-RSA-AES256-GCM-SHA384/TLS1.2:DHE-RSA-AES256-GCM-SHA384/DTLS1.2:DHE-RSA-AES256-SHA/TLS1.0:DHE-RSA-AES256-SHA/TLS1.1:DHE-RSA-AES256-SHA/TLS1.2:DHE-RSA-AES256-SHA/DTLS1.2:DHE-RSA-AES256-SHA/DTLS1.0:DHE-RSA-AES256-SHA256/TLS1.2:DHE-RSA-AES256-SHA256/DTLS1.2:DHE-RSA-CAMELLIA128-SHA/TLS1.0:DHE-RSA-CAMELLIA128-SHA/TLS1.1:DHE-RSA-CAMELLIA128-SHA/TLS1.2:DHE-RSA-CAMELLIA128-SHA/DTLS1.2:DHE-RSA-CAMELLIA256-SHA/TLS1.0:DHE-RSA-CAMELLIA256-SHA/TLS1.1:DHE-RSA-CAMELLIA256-SHA/TLS1.2:DHE-RSA-CAMELLIA256-SHA/DTLS1.2:TLS13-AES128-GCM-SHA256/TLS1.3:TLS13-AES256-GCM-SHA384/TLS1.3 DH-Groups DEFAULT:X25519MLKEM768 Signature Algorithms DEFAULT
    tmsh
    root@(localhost)(pid-6084)(cfg-sync Standalone)(Active)(/Common)(tmos)# create ltm cipher group TMSH_PQC allow add { TMSH_PQC }
    root@(localhost)(pid-6084)(cfg-sync Standalone)(Active)(/Common)(tmos)# list ltm cipher group TMSH_PQC ltm cipher group TMSH_PQC { allow { TMSH_PQC { } } }
    root@(localhost)(pid-6084)(cfg-sync Standalone)(Active)(/Common)(tmos)# show ltm cipher group TMSH_PQC --------------------------- Ltm::Cipher::Group --------------------------- Name TMSH_PQC Cipher Result ECDHE-RSA-AES128-GCM-SHA256/TLS1.2:ECDHE-RSA-AES128-GCM-SHA256/DTLS1.2:ECDHE-RSA-AES128-CBC-SHA/TLS1.0:ECDHE-RSA-AES128-CBC-SHA/TLS1.1:ECDHE-RSA-AES128-CBC-SHA/DTLS1.0:ECDHE-RSA-AES128-CBC-SHA/TLS1.2:ECDHE-RSA-AES128-CBC-SHA/DTLS1.2:ECDHE-RSA-AES128-SHA256/TLS1.2:ECDHE-RSA-AES128-SHA256/DTLS1.2:ECDHE-RSA-AES256-GCM-SHA384/TLS1.2:ECDHE-RSA-AES256-GCM-SHA384/DTLS1.2:ECDHE-RSA-AES256-CBC-SHA/TLS1.0:ECDHE-RSA-AES256-CBC-SHA/TLS1.1:ECDHE-RSA-AES256-CBC-SHA/DTLS1.0:ECDHE-RSA-AES256-CBC-SHA/TLS1.2:ECDHE-RSA-AES256-CBC-SHA/DTLS1.2:ECDHE-RSA-AES256-SHA384/TLS1.2:ECDHE-RSA-AES256-SHA384/DTLS1.2:AES128-GCM-SHA256/TLS1.2:AES128-GCM-SHA256/DTLS1.2:AES128-SHA/TLS1.0:AES128-SHA/TLS1.1:AES128-SHA/TLS1.2:AES128-SHA/DTLS1.2:AES128-SHA/DTLS1.0:AES128-SHA256/TLS1.2:AES128-SHA256/DTLS1.2:AES256-GCM-SHA384/TLS1.2:AES256-GCM-SHA384/DTLS1.2:AES256-SHA/TLS1.0:AES256-SHA/TLS1.1:AES256-SHA/TLS1.2:AES256-SHA/DTLS1.2:AES256-SHA/DTLS1.0:AES256-SHA256/TLS1.2:AES256-SHA256/DTLS1.2:CAMELLIA128-SHA/TLS1.0:CAMELLIA128-SHA/TLS1.1:CAMELLIA128-SHA/TLS1.2:CAMELLIA128-SHA/DTLS1.2:CAMELLIA256-SHA/TLS1.0:CAMELLIA256-SHA/TLS1.1:CAMELLIA256-SHA/TLS1.2:CAMELLIA256-SHA/DTLS1.2:ECDHE-ECDSA-AES128-GCM-SHA256/TLS1.2:ECDHE-ECDSA-AES128-GCM-SHA256/DTLS1.2:ECDHE-ECDSA-AES128-CCM/TLS1.2:ECDHE-ECDSA-AES128-CCM/DTLS1.2:ECDHE-ECDSA-AES128-CCM8/TLS1.2:ECDHE-ECDSA-AES128-CCM8/DTLS1.2:ECDHE-ECDSA-AES128-SHA/TLS1.0:ECDHE-ECDSA-AES128-SHA/TLS1.1:ECDHE-ECDSA-AES128-SHA/TLS1.2:ECDHE-ECDSA-AES128-SHA/DTLS1.2:ECDHE-ECDSA-AES128-SHA256/TLS1.2:ECDHE-ECDSA-AES128-SHA256/DTLS1.2:ECDHE-ECDSA-AES256-GCM-SHA384/TLS1.2:ECDHE-ECDSA-AES256-GCM-SHA384/DTLS1.2:ECDHE-ECDSA-AES256-CCM/TLS1.2:ECDHE-ECDSA-AES256-CCM/DTLS1.2:ECDHE-ECDSA-AES256-CCM8/TLS1.2:ECDHE-ECDSA-AES256-CCM8/DTLS1.2:ECDHE-ECDSA-AES256-SHA/TLS1.0:ECDHE-ECDSA-AES256-SHA/TLS1.1:ECDHE-ECDSA-AES256-SHA/TLS1.2:ECDHE-ECDSA-AES256-SHA/DTLS1.2:ECDHE-ECDSA-AES256-SHA384/TLS1.2:ECDHE-ECDSA-AES256-SHA384/DTLS1.2:DHE-RSA-AES128-GCM-SHA256/TLS1.2:DHE-RSA-AES128-GCM-SHA256/DTLS1.2:DHE-RSA-AES128-SHA/TLS1.0:DHE-RSA-AES128-SHA/TLS1.1:DHE-RSA-AES128-SHA/TLS1.2:DHE-RSA-AES128-SHA/DTLS1.2:DHE-RSA-AES128-SHA/DTLS1.0:DHE-RSA-AES128-SHA256/TLS1.2:DHE-RSA-AES128-SHA256/DTLS1.2:DHE-RSA-AES256-GCM-SHA384/TLS1.2:DHE-RSA-AES256-GCM-SHA384/DTLS1.2:DHE-RSA-AES256-SHA/TLS1.0:DHE-RSA-AES256-SHA/TLS1.1:DHE-RSA-AES256-SHA/TLS1.2:DHE-RSA-AES256-SHA/DTLS1.2:DHE-RSA-AES256-SHA/DTLS1.0:DHE-RSA-AES256-SHA256/TLS1.2:DHE-RSA-AES256-SHA256/DTLS1.2:DHE-RSA-CAMELLIA128-SHA/TLS1.0:DHE-RSA-CAMELLIA128-SHA/TLS1.1:DHE-RSA-CAMELLIA128-SHA/TLS1.2:DHE-RSA-CAMELLIA128-SHA/DTLS1.2:DHE-RSA-CAMELLIA256-SHA/TLS1.0:DHE-RSA-CAMELLIA256-SHA/TLS1.1:DHE-RSA-CAMELLIA256-SHA/TLS1.2:DHE-RSA-CAMELLIA256-SHA/DTLS1.2:TLS13-AES128-GCM-SHA256/TLS1.3:TLS13-AES256-GCM-SHA384/TLS1.3 DH-Groups Result P256:X25519:P384:FFDHE2048:FFDHE3072:FFDHE4096:X25519MLKEM768 Signature Algorithms Result RSA-PKCS1-SHA256:RSA-PSS-SHA256:ECDSA-SHA256:RSA-PKCS1-SHA384:RSA-PSS-SHA384:ECDSA-SHA384:RSA-PKCS1-SHA512:RSA-PSS-SHA512:ECDSA-SHA512 root@(localhost)(pid-6084)(cfg-sync Standalone)(Active)(/Common)(tmos)#
    tmsh
    root@(localhost)(pid-6084)(cfg-sync Standalone)(Active)(/Common)(tmos)# create ltm profile client-ssl TMSH_PQC cipher-group TMSH_PQC options { dont-insert-empty-fragments } ciphers none
    root@(localhost)(pid-6084)(cfg-sync Standalone)(Active)(/Common)(tmos)# list ltm profile client-ssl TMSH_PQC ltm profile client-ssl TMSH_PQC { app-service none cert-key-chain { default { cert default.crt key default.key } } cipher-group pqc ciphers none inherit-ca-certkeychain true inherit-certkeychain false options { dont-insert-empty-fragments } }
