Manual Chapter :
Managing Client-Side HTTP Traffic Using a CA-Signed RSA Certificate
Applies To:
Show Versions
Overview: Managing client-side HTTP traffic using a CA-signed RSA certificate
When you want to manage HTTP traffic over SSL, you can configure the BIG-IP system to perform the SSL handshake that target web servers normally perform.
A common way to configure the BIG-IP system is to enable client-side SSL, which makes it
possible for the system to decrypt client requests before sending them on to a server, and
encrypt server responses before sending them back to the client. In this case, you need to
install only one SSL key/certificate pair on the BIG-IP system.
This implementation uses a certificate signed by an RSA certificate authority (CA) to
authenticate HTTP traffic.
Task summary
To implement client-side and server-side authentication using HTTP and SSL with a CA-signed
certificate, you perform a few basic configuration tasks.
Task list
Requesting an RSA certificate from a certificate authority
You can generate a request for an RSA digital certificate and then copy or submit
it to a trusted certificate authority for signature.
- On the Main tab, click .The Traffic Certificate Management screen opens.
- ClickCreate.
- In theNamefield, type a unique name for the SSL certificate.
- From theIssuerlist, selectCertificate Authority.
- In theCommon Namefield, type a name.This is typically the name of a web site, such aswww.siterequest.com.
- In theDivisionfield, type your department name.
- In theOrganizationfield, type your company name.
- In theLocalityfield, type your city name.
- In the orState or Provincefield, type your state or province name.
- From theCountrylist, select the name of your country.
- In theE-mail Addressfield, type your email address.
- In theLifetimefield, type a number of days, or retain the default,365.
- In theSubject Alternative Namefield, type a name.This name is embedded in the certificate for X509 extension purposes.By assigning this name, you can protect multiple host names with a single SSL certificate.
- In theChallenge Passwordfield, type a password.
- In theConfirm Passwordfield, re-type the password you typed in theChallenge Passwordfield.
- From theKey Typelist, selectRSA.
- From theSizelist, select a key size, in bits.
- ClickFinished.The Certificate Signing Request screen displays.
- Do one of the following to download the request into a file on your system.
- In theRequest Textfield, copy the certificate.
- ForRequest File, click the button.
- Follow the instructions on the relevant certificate authority web site for either pasting the copied request or attaching the generated request file.
The generated RSA certificate request is submitted to a trusted certificate
Creating a custom HTTP profile
An HTTP profile defines the way that you want the BIG-IPsystem to manage HTTP traffic.
Other HTTP profile types
(HTTP Compression and Web Acceleration) enable you to configure compression and
cache settings, as required. Use of these profile types is
optional.
- On the Main tab, click .The HTTP profile list screen opens.
- ClickCreate.The New HTTP Profile screen opens.
- In theNamefield, type a unique name for the profile.
- From theParent Profilelist, selecthttp.
- Select theCustomcheck box.
- Modify the settings, as required.
- ClickFinished.
The custom HTTP profile now appears in the HTTP profile list screen.
Creating a Client SSL profile
Create a Client SSL profile to
authenticate and decrypt/encrypt client-side application traffic.
- On the Main tab, click .The Client SSL profile list screen opens.
- ClickCreate.The New Client SSL Profile screen opens.
- Configure all profile settings as needed.
- ClickFinished.
After creating the Client SSL profile and assigning the profile to a virtual server,
the BIG-IP system can apply SSL security to the type of application traffic for which
the virtual server is configured to listen.
Create a pool to process HTTP traffic
You can create a pool of web servers to process HTTP requests.
- On the Main tab, click .The Pool List screen opens.
- ClickCreate.The New Pool screen opens.
- In theNamefield, type a unique name for the pool.
- For theHealth Monitorssetting, from theAvailablelist, select thehttpmonitor and move the monitor to theActivelist.
- From theLoad Balancing Methodlist, select how the system distributes traffic to members of this pool.The default isRound Robin.
- For thePriority Group Activationsetting, specify how to handle priority groups:
- SelectDisabledto disable priority groups. This is the default option.
- SelectLess than, and in theAvailable Membersfield type the minimum number of members that must remain available in each priority group in order for traffic to remain confined to that group.
- Using theNew Memberssetting, add each resource that you want to include in the pool:
- Type an IP address in theAddressfield.
- Type80in theService Portfield, or selectHTTPfrom the list.
- (Optional) Type a priority number in thePriorityfield.
- ClickAdd.
- ClickFinished.
Creating a virtual server for client-side HTTP traffic
You can specify a virtual server to be either a host virtual server or a network
virtual server to manage HTTP traffic over SSL.
- On the Main tab, click .The Virtual Server List screen opens.
- ClickCreate.The New Virtual Server screen opens.
- In theNamefield, type a unique name for the virtual server.
- For theDestination Address/Masksetting, confirm that theHostbutton is selected, and type the IP address in CIDR format.The supported format is address/prefix, where the prefix length is in bits. For example, an IPv4 address/prefix is10.0.0.1or10.0.0.0/24, and an IPv6 address/prefix isffe1::0020/64or2001:ed8:77b5:2:10:10:100:42/64. When you use an IPv4 address without specifying a prefix, the BIG-IP system automatically uses a/32prefix.The IP address you type must be available and not in the loopback network.
- In theService Portfield, type443, or selectHTTPSfrom the list.
- From theHTTP Profilelist, select the HTTP profile that you previously created.
- For theSSL Profile (Client)setting, from theAvailablelist, select the name of the Client SSL profile you previously created and move the name to theSelectedlist.
- In the Resources area, from theDefault Poollist, select the name of the pool that you created previously.
- ClickFinished.
After performing this task, the virtual server appears in the Virtual Server List
screen.
Implementation results
After you complete the tasks in this implementation, the BIG-IP system
can authenticate and decrypt HTTP traffic coming from a client system, using an RSA digital
certificate. The BIG-IP system can also re-encrypt server responses before sending them back to
the client.
