Updated Date: 07/07/2026
Advanced Routing commands in ZebOS, tmsh, and iControl REST
The structure of commands for ZebOS, tmsh, and iControl REST are different, and users who are familiar with ZebOS will want to understand the basic rules underlying these differences between commands. Here you can compare the same advanced routing command in ZebOS IMI, tmsh, and iControl REST.
| Description | ZebOS IMI | tmsh | iControl REST |
| Create BGP instance | router bgp 65001 | create net routing bgp test local-as 65001 | curl -sk -u admin:admin https://localhost/mgmt/tm/net/routing/bgp -H ‘Content-Type: application/json’ -X POST -d ‘{“name”:“test”,“localAs”:“65001”}’ |
| Create BGP Neighbor | neighbor 1.1.1.1 remote-as 65002 | modify net routing bgp test neighbor add { 1.1.1.1 { remote-as 65002 } } | curl -sk -u admin:admin https://localhost/mgmt/tm/net/routing/bgp/ |
| Show BGP Status | show bgp neighbor | show net routing bgp | curl -sk -u admin:admin https://localhost/mgmt/tm/net/routing/bgp/stats |
| Delete BGP instance | no router bgp 65001 | delete net routing bgp test | curl -sk -u admin:admin https://localhost/mgmt/tm/net/routing/bgp/ |
| Add BGP Network | network 10.10.10.0/24 | modify net routing bgp test network add { 10.10.10.0/24 } | curl -sk -u admin:admin https://localhost/mgmt/tm/net/routing/bgp/ |
