Manual Chapter : Restore the original ZebOS routing configuration from iControl REST
Applies To:
  • BIG-IP LTM
    13.1.1, 13.1.0
The routing config sync status is in the prompt. If you encounter a config sync failure that you are not able to fix, or if you need to return to your original ZebOS routing configuration, you can restore the ZebOS configuration with the backed up file. Restoring a UCS should fully restore the ZebOS configuration. Note that restoring a UCS interrupts routing.
  1. Delete the neighbor. For example:
    curl -k -u admin:admin https://10.144.130.174/mgmt/tm/net/routing/bgp/testBGP /neighbor/5.5.5.5/ -H "Content-Type: application/json" -X DELETE
  2. To verify that the neighbor is deleted:
    tmsh list net routing
  3. Delete all other objects including configured prefix lists and access lists.
    Use the command curl -k -u admin:admin https://10.144.130.174/mgmt/tm/net/routing/<object>/all -H "Content-Type: application/json" -X DELETE where <object> is the routing object type.
    For example: curl -k -u admin:admin https://10.144.130.174/mgmt/tm/net/routing/bgp/testBGP -H "Content-Type: application/json" -X DELETE
You should now be able to continue working on your configuration in ZebOS imish.
