Manual Chapter :
Enabling and disabling the Debug log level
Applies To:
Show Versions
BIG-IP LTM
- 21.1.0 , 21.0.0, 17.5.1, 17.5.0, 17.1.3, 17.1.2, 17.1.1, 17.1.0, 17.0.0, 16.1.6, 16.1.5, 16.1.4, 16.1.3, 16.1.2, 16.1.1, 16.1.0, 16.0.1, 16.0.0, 15.1.8, 15.1.7, 15.1.6, 15.1.5, 15.1.4, 15.1.3, 15.1.2, 15.1.1, 15.1.0, 15.0.1, 15.0.0, 14.1.5, 14.1.4, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0
BIG-IP DNS
The Secure Vault feature logs information to the
/var/log/secure
file. You can use the TMOS Shell to manage the log level for Secure Vault logging.
- Enable logging at the Debug level by typing this command at a BIG-IP system prompt:tmsh modify sys syslog auth-priv-from debug
- To return Secure Vault logging to the default log level, type this command at the system prompt:tmsh modify sys syslog auth-priv-from notice
