Manual Chapter :
Syncing the master key when creating a device group
Applies To:
Show Versions
BIG-IP LTM
- 21.1.0 , 21.0.0, 17.5.1, 17.5.0, 17.1.3, 17.1.2, 17.1.1, 17.1.0, 17.0.0, 16.1.6, 16.1.5, 16.1.4, 16.1.3, 16.1.2, 16.1.1, 16.1.0, 16.0.1, 16.0.0, 15.1.8, 15.1.7, 15.1.6, 15.1.5, 15.1.4, 15.1.3, 15.1.2, 15.1.1, 15.1.0, 15.0.1, 15.0.0, 14.1.5, 14.1.4, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0
BIG-IP DNS
When you attempt to create a Device Service Clustering (DSC) device group, the device that you are logged in to sends a copy of its BIG-IP configuration, including the master key, to all other devices that join the device group. In a working device group, the same master key lives on all devices.
For example, suppose you have two devices,
Device_A
and Device_B
, and you want to create a device group. You can log in to Device_A
, navigate to the Device Trust settings, and specify that you want Device_B
to be the device that joins Device_A
to comprise the trust domain. Then, while still logged in to Device_A
, you can create a device group with both devices as members.In this case, when
Device_B
joins the device group, it receives a copy of Device_A
's master key, as part of the initial config sync that the BIG-IP system does to form the device group.
