Manual Chapter : Resetting a vCMP guest's master key
Applies To:
Show Versions Show Versions
BIG-IP LTM
  • 21.1.0 , 21.0.0, 17.5.1, 17.5.0, 17.1.3, 17.1.2, 17.1.1, 17.1.0, 17.0.0, 16.1.6, 16.1.5, 16.1.4, 16.1.3, 16.1.2, 16.1.1, 16.1.0, 16.0.1, 16.0.0, 15.1.8, 15.1.7, 15.1.6, 15.1.5, 15.1.4, 15.1.3, 15.1.2, 15.1.1, 15.1.0, 15.0.1, 15.0.0, 14.1.5, 14.1.4, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0
BIG-IP DNS
Manual Chapter
F5 recommends that for any new BIG-IP system, you reset the master key as part of the initial system setup. You can perform the following task to reset the master key on a vCMP guest.
  1. Using a program such as PuTTY, open a console window on the vCMP guest.
  2. Log into the guest.
  3. At the system prompt, reset the guest's master key by typing this command, specifying a new password in the process:
    tmsh modify /sys crypto master-key prompt-for-password
