Updated Date: 09/28/2026
Implementing FIX Low Latency Mode
You can use the TMOS Shell (tmsh) to choose whether to use the FIX low latency firmware. To use a BIG-IP system to manage low latency electronic trading functionality, you must first obtain a specific license. The license must enable the FIX Low Latency feature.
Connect to the system using the serial console.
Log in to the command-line interface of the system using the root account.
Open the TMOS Shell (tmsh).
tmsh -
Enable the FIX LL firmware.
modify sys db pva.fix.lowlatency value enable -
Reboot the system to update the FPGA.
rebootNote: If you are switching to the FIX Low Latency firmware for the first time, the system performs an HSB update to load the new firmware. Do not interrupt the progress of the firmware update. When the firmware update completes, the system reboots, and then you will be able to use the FIX Low Latency firmware.
To switch back to the default firmware:
Disable the FIX Low Latency firmware.
modify sys db pva.fix.lowlatency value disable -
reboot
F5 r5000, r10000, and r12000 systems provide support for Financial Information eXchange (FIX) protocol connections for electronic trading between financial institutions. This enables tenants running on the system to manage electronic trading traffic for both low latency and intelligent load balancing.
Note: rSeries does not support v16.x as per https://my.f5.com/manage/s/article/K86001294.
If your software license includes the FIX Low Latency add-on keys, they are activated for tenants on your F5 r5000, r10000, and r12000 Series systems automatically, when you initially register the license. If you purchase these add-on keys later, you can install the keys from the CLI or via API or via webUI. An example of installation using CLI:
Connect using SSH to the management IP address.
Log in to the command line interface (CLI) of the F5 rSeries system using an account with admin access.
When you log in to the system, you are in user (operational) mode.
Change to config mode.
configThe CLI prompt changes to include
(config). -
Install the add-on keys.
text appliance-1(config)# system licensing install add-on-keys [ C123456-7890123 ] Proceed? [yes/no]: yesThis license installation triggers a system reboot; data-plane and management connectivity will be disrupted.
Result: License installed successfully.The system shows a message confirming that the installed license enables the add-on keys, and the system reboots automatically.
You can create a custom Fast L4 profile to manage Layer 4 traffic for FIX Low Latency.
On the Main tab, click Local Traffic > Profiles > Protocol > Fast L4. The Fast L4 screen opens.
Click Create. The New Fast L4 profile screen opens.
In the Name field, type a unique name for the profile.
Select the Custom check box.
From the PVA Acceleration list, select Dedicated.
Note: This option is available on the r5900 tenant.
Clear the PVA Flow Aging and PVA Flow Evict check boxes.
For the PVA Offload Dynamic setting, retain the default value (Enabled).
For the PVA Dynamic Client Packets setting, retain the default value (1).
For the PVA Dynamic Server Packets setting, retain the default value (0).
Select the Loose Close check box only for a one-arm virtual server configuration.
Set the TCP Close Timeout setting, according to the type of traffic that the virtual server will process.
Select the Software SYN Cookie Protection check box.
Note: This checkbox is not available for tenants with TMOS 17.1.1.3 0.0.5 running on r5900.
Click Finished.
The custom Fast L4 profile appears in the list of Fast L4 profiles.
You can create the FIX profile for low latency electronic trading with FIX load balancing.
On the Main tab, click Local Traffic > Profiles > Services > FIX. The FIX profile list screen opens.
Click Create. The new FIX Profile screen opens.
From the Parent Profile list, select a parent profile.
From the Report Log Publisher list, select the publisher for error messages and status reports.
Click Finished.
The FIX profile is configured for low latency electronic trading with FIX load balancing.
However, when this profile is created for Late Binding, a virtual server can choose a server pool based on the contents of the FIX connection’s initial packet. The Late Binding feature allows combining load balancing with low latency.
This is a simplified FIX profile. The low latency path goes through ePVA hardware, which does not examine the contents of each FIX packet. The only packet the BIG-IP software examines is the logon packet, which the BIG-IP system uses to choose a server pool. Therefore, most of the features in the FIX-profile screen (such as tag substitution) are ignored for low latency trading.
Before starting this task:
Decide on the IP addresses or FQDNs for the servers that you want to include in your server pool.
If your system is using DHCP, make sure your DNS servers are not configured for round robin DNS resolutions; instead, they should be configured to return all available IP addresses in a resolution.
Use this task to create a pool of servers with pool members. The pool identifies which servers you want the virtual server to send client requests to. As an option, you can identify the servers by their FQDNs instead of their IP addresses. In this way, the system automatically updates pool members whenever you make changes to their corresponding server IP addresses on your network.
On the Main tab, click Local Traffic > Pools.
The Pool List screen opens.
Click Create.
The New Pool screen opens.
In the Name field, type a unique name for the pool.
For the Health Monitors setting, from the Available list, select a monitor and move the monitor to the Active list.
Note: A pool containing nodes represented by FQDNs cannot be monitored by inband or sasp monitors.
From the Load Balancing Method list, select how the system distributes traffic to members of this pool. The default is Round Robin.
For the New Members setting, add each server that you want to include in the pool:
Select New Node or New FQDN Node.
(Optional) In the Node Name field, type a name for the node.
If you chose New Node, then in the Address field, type the IP address of the server. If you chose New FQDN Node, then in the FQDN field, type the FQDN of the server.
Note: If you want to use FQDNs instead of IP addresses, you should still type at least one IP address. Typing one IP address ensures that the system can find a pool member if a DNS server is not available.
For the Service Port option, pick a service from the list.
If you are using FQDNs for the server names, then for Auto Populate, keep the default value of Enabled. When you leave Auto Populate turned on, the system creates an ephemeral node for each IP address returned as an answer to a DNS query. Also, when a DNS answer shows that the IP address of an ephemeral node no longer exists, the system deletes the ephemeral node.
Click Add.
Do this step again for each node.
Click Finished.
After you create a server pool, profile(s), and (optionally) iRule, you need to create a virtual server that references those components.
On the Main tab, click Local Traffic > Virtual Servers. The Virtual Server List screen opens.
Click Create. The New Virtual Server screen opens.
In the Name field, type a unique name for the virtual server.
From the Type list, select Performance (Layer 4).
In the Destination Address field, type the IP address in CIDR format. This is the address to which the FIX clients send their FIX transmissions. The supported format is address/prefix, where the prefix length is in bits. For example, an IPv4 address/prefix is
10.0.0.1or10.0.0.0/24, and an IPv6 address/prefix isffe1::0020/64or2001:ed8:77b5:2:10:10:100:42/64. When you use an IPv4 address without specifying a prefix, the BIG-IP system automatically uses a/32prefix. The IP address you type must be available and not in the loopback network. -
In the Service Port field, specify a port number or select a type from the port list to listen to a virtual server.
Note:
- You can select
*to listen to all the ports. - You can direct traffic to different pools using iRule based on the port number to listen to multiple ports.
- You can select
From the Configuration list, select Advanced.
From the Protocol list, select TCP.
From the Protocol Profile (Client) list, select the custom Fast L4 profile you defined for low latency FIX trading.
Go to the FIX Profile list and select the custom FIX profile you defined for low latency trading.
For the Port Translation setting, clear the Enabled check box.
Note: Clearing the Enabled check box disables network address translation (NAT) functionality. If you require NAT, you must select the Enabled check box.
In the Resources area of the screen, from the Default Pool list, select the pool name for FIX streams. This pool is for streams that do not match your iRule(s).
Click Finished.
The virtual server is configured to use the specified Fast L4 profile and pool. If a client initiates a FIX connection with this virtual server, the connection uses the Fast L4 (ePVA) hardware.
This implementation configures a BIG-IP® system to manage low latency electronic trading functionality, optimizing the system for predictable latency and jitter. Clients who send FIX streams to the virtual server’s destination address all receive this low latency service. The virtual server intelligently distributes the streams to different server pools based on information in each stream’s FIX logon packet.
