Manual Chapter :
About client-side and server-side SSL
profiles
Applies To:
Show Versions
BIG-IP AAM
- 14.1.3, 14.1.2, 14.1.0
BIG-IP APM
BIG-IP Analytics
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
profiles
You can manage the way that the BIG-IP system processes SSL application traffic by configuring
two types of SSL profiles: A Client SSL profile, a Server SSL profile, or both. These profiles affect the
way that the system manages SSL traffic passing through the system.
When you configure Client
SSL or Server SSL profiles and assign them to a virtual server, the BIG-IP system
offloads SSL processing from the destination server. This offloading not only conserves resource on destination servers, but enables the BIG-IP system to
customize SSL traffic processing according to your configuration specifications.
