Manual Chapter :
About dynamic routing
for redundant system configurations
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
If the BIG-IP system that you are configuring for dynamic routing is part of
a redundant system configuration, you should consider these factors:
- You must configure the dynamic routing protocols on each member of the device group.
- For protocols that include the router ID attribute, you should verify that each member of the device group has a unique router ID.
- When you configure Route Health Injection (RHI), only active device group members advertise routes to virtual addresses.
