Manual Chapter :
About the Bidirectional Forwarding Detection protocol
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
Bidirectional Forwarding Detection (BFD)
is an industry-standard network protocol
on the BIG-IP® system that provides a common service to the dynamic routing
protocols BGPv4, OSPFv2, and IS-IS. Enabled on a per-route domain basis, BFD identifies changes
to the connectivity between two forwarding engines, or endpoints, by transmitting periodic BFD
control packets on each path between the two endpoints. When either endpoint fails to receive
these control packets for a specific duration of time, the connectivity between the endpoints is
considered lost, and BFD notifies the associated dynamic routing protocols. In general, BFD
detects connectivity changes more rapidly than the endpoints' standard Hello mechanisms, leading
to quicker network convergence, which is highly desirable to data center applications.BFD operates by establishing a session between two endpoints, sending BFD control packets over
the link. If more than one link exists between two endpoints, BFD can establish multiple sessions
to monitor each link.
A BFD session can operate in one of two modes, either asynchronous mode or demand mode:
- You configure BFD to operate inasynchronous modewhen you want both endpoints to verify connectivity by periodically sending Hello packets to each other. This is the most commonly-used mode.
- You configure BFD to operate indemand modewhen you want the endpoints to use another way to verify connectivity to each other instead of sending Hello packets. For example, the endpoints might verify connectivity at the underlying physical layer. Note, however, that in demand mode, either host can send Hello packets if needed.
BFD failure detection between two BIG-IP systems does not trigger failover.
