Manual Chapter :
Accessing the IMI
Shell
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
Accessing the IMI
Shell
Perform this task when you want to use IMI Shell (
imish
) to configure any of the
dynamic routing protocols. Note that if you are using the route domains feature, you
must specify the route domain pertaining to the dynamic routing protocol that you
want to configure.- Open a console window, or an SSH session using the management port, on a BIG-IP device.
- Use your user credentials to log in to the system.
- At the command prompt, typetmsh.This opens thetmshshell.
- Type this command:run /util imish.-rIDIf the route domain for the protocol you want to configure is the default route domain for the current partition, you do not need to use the-roption to specify the route domain ID.This command invokes the IMI shell.
You can now use any of the IMI shell commands.
