Manual Chapter :
About graceful restart
on the VIPRION system
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
With the
graceful restart
function, the
dynamic routing protocol control plane moves from one blade to another without disruption to
traffic. Graceful restart is enabled for most supported protocols and address families by
default.To operate successfully, the graceful restart function must be supported and
enabled on all peer routers with which the VIPRION®
system exchanges routing information. If one or more peer routers does not support graceful
restart for one or more enabled dynamic routing protocols, a change in the primary blade causes
full dynamic routing reconvergence, and probably traffic disruption. The traffic disruption is
caused primarily by peer routers discarding routes advertised by the VIPRION system.
The BIG-IP system always preserves complete forwarding information (TMM and
host route tables) on VIPRION systems during primary blade changes, regardless of support for
graceful restart on peer routers.
