Manual Chapter :
Operational modes for primary and secondary blades
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
Enabled dynamic routing protocols run on every blade in a cluster in one of these operational
modes: MASTER, STANDBY, or SLAVE.
This table shows the operational modes for primary and secondary blades, on both the active cluster and the standby cluster.
Blade Type | Active Cluster | Standby Cluster | Notes |
Primary | MASTER mode | STANDBY mode | The dynamic routing protocols:
Secondary | SLAVE mode | SLAVE mode | The dynamic routing protocols:
In MASTER and STANDBY modes, all routes learned by way of dynamic routing protocols on the primary blade are (in real-time) propagated to all secondary blades. The difference between MASTER and STANDBY mode is in the parameters of advertised routes, with the goal to always make the active unit the preferred next hop for all advertised routes.
The transition from SLAVE to MASTER or STANDBY mode takes advantage of standard dynamic routing
protocol graceful restart functionality.
