Manual Chapter :
Runtime monitoring of individual blades
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
The BIG-IP system automatically copies the startup configuration to all secondary blades and
loads the new configuration when the running configuration is saved on the primary blade.
You can display information about the runtime state of both the primary and secondary blades.
However, some information displayed on secondary blades might differ from the information on the
primary blade. For troubleshooting, you should use the information displayed on the primary blade
only, because only the primary blade both actively participates in dynamic routing communication
and controls route tables on all blades.
