Manual Chapter :
Dynamic routing on the BIG-IP system
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
By enabling and configuring any of the BIG-IP® advanced routing modules,
you can configure dynamic routing on the BIG-IP system. You enable one or more advanced routing
modules, as well as the Bidirectional Forwarding Detection (BFD) protocol, on a per-route-domain
basis. Advanced routing module configuration on the BIG-IP system provides these functions:
- Dynamically adds routes to the Traffic Management Microkernel (TMM) and host route tables.
- Advertises and redistributes routes for BIG-IP virtual addresses to other routers.
- When BFD is enabled, detects failing links more quickly than would normally be possible using the dynamic routing protocols' own detection mechanisms.
On the BIG-IP system, directly-connected and static routes take precedence over dynamically-learned routes.
