Manual Chapter :
Location of startup configuration for advanced routing modules
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
When you enable advanced routing modules for a route domain, the BIG-IP system creates a
dynamic routing startup configuration. Each route domain has its own dynamic routing
configuration, located in the folder
/config/zebos/rd
where n
n
is the numeric route domain ID.F5 Networks strongly discourages manual modifications to the startup
configuration (such as by using a text editor). Doing so might lead to unexpected
results.
