Manual Chapter :
Relationship of advanced routing modules and BFD to route domains
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
For each route domain on the BIG-IP system (including route domain
0
you can enable one or more dynamic routing protocols, as well as the network protocol
Bidirectional Forwarding Detection (BFD). For example, you can enable BGP4 and OSPFv3 on a
specific route domain. Use of dynamic routing protocols for a route domain is optional.When you enable dynamic routing on a specific route domain, the BIG-IP system creates a dynamic
routing instance. This dynamic routing instance is made up of the core dynamic routing daemons
imi
and nsm
), as well each relevant dynamic
routing protocol daemon. If you enable BFD, the BFD instance is made up of the oamd
protocol daemon. Thus, each
dynamic routing instance for a route domain has a separate configuration. You manage a dynamic
routing configuration using the IMI shell (imish
) within the BIG-IP Traffic
Management Shell (tmsh
