Manual Chapter :
About translation addresses
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
You can specify the translation addresses that you want to map to your original IP addresses. A translation address can be in these three forms:
- An IP Address
- When creating a SNAT, you can specify a particular IP address that you want the SNAT to use as a translation address.
- A SNAT pool
- Specifying this value allows you to specify an existing SNAT pool to which you want to map your original IP address.
- SNAT automap
- Similar to a SNAT pool, the SNAT automap feature allows you to map one or more original IP addresses to a pool of translation addresses. With the SNAT automap feature, you do not need to create the pool. Instead, Local Traffic Manager effectively creates a pool for you, using self IP addresses as the translation addresses for the pool.
