Manual Chapter :
Comparison of NATs and SNATs
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
A SNAT is similar to a NAT, except for the differences listed in this
table.
NATs | SNATs |
You can map only one original address to a translation address. | You can map multiple original addresses to a single translation address. You can
even map all node addresses on your network to a single public IP address, in a single
SNAT object. |
All ports on the internal node are open. | By default, SNATs support UDP and TCP only. This makes a SNAT more secure than a
NAT. |
Local Traffic Manager does not track NAT
connections. | Local Traffic Manager tracks SNAT connections, which, in turn, allows SNATs and
virtual servers to use the same public IP addresses. |
You must explicitly enable a NAT on the internal VLAN where the internal node’s
traffic arrives on the BIG-IP system. | By default, a SNAT that you create is enabled on all VLANs. |
