Manual Chapter :
About traffic load balancing across TMM instances
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
On eDAG-enabled hardware platforms, you can configure the BIG-IP® system to scatter stateless traffic in round-robin fashion
across TMM instances. This feature is particularly beneficial for networks
with heavy Domain Name Server (DNS) or Session Initiation Protocol (SIP)
traffic, as well as for the management of Distributed Denial of Service (DDoS)
attacks.
You can configure this feature in one of two modes:
- Global
- Across TMM instances across multiples blades or HSBs on the system. You configure this mode by setting a global value using the Traffic Management Shell (tmsh). This is the default mode.
- Local
- Per individual high-speed bridge (HSB). In this case, the system load balances the traffic across TMM instances within a single blade or HSB but not across multiple blades or HSBs. You configure this mode when you create or modify a VLAN on the BIG-IP system.
