Manual Chapter :
About filter
expression creation
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
About filter
expression creation
To match incoming packets, the BIG-IP system must use a filter expression. A
filter
expression
specifies the criteria that you want the BIG-IP system to use when filtering
packets. For example, the BIG-IP system can filter packets based on the source or destination IP
address in the header of a packet.Using the BIG-IP Configuration utility, you can create a filter expression
in either of two ways:
- You can write your own expression, using a Filter Expression box.
- You can specify a set of criteria (such as source or destination IP addresses) that you want the BIG-IP system to use when filtering packets. When you use this method, the BIG-IP system builds a filter expression for you.
You can have as many rules as you want, limited only by the available
memory. Of course, the more statements you have, the more challenging it is to understand and
maintain your packet filters.
