Manual Chapter :
Introduction to packet filtering
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
Packet filters enhance network security by specifying whether a BIG-IP® system interface should accept or reject certain packets based on criteria that you specify. Packet filters enforce an access policy on incoming traffic. They apply to incoming traffic only.
You implement packet filtering by creating packet filter rules, using the BIG-IP Configuration
utility. The primary purpose of a packet filter rule is to define the criteria that you want the
BIG-IP system to use when filtering packets. Examples of criteria that you can specify in a
packet filter rule are:
- The source IP address of a packet
- The destination IP address of a packet
- The destination port of a packet
You specify the criteria for applying packet filter rules within an expression. When creating a
packet filter rule, you can instruct the BIG-IP system to build an expression for you, in which
case you need only choose the criteria from predefined lists, or you can write your own
expression text, using the syntax of the
tcpdump
utility. For more information
on the tcpdump
utility, see the online man page for the
tcpdump
command.Unlike most IP address
configuration settings in the BIG-IP Configuration utility that require the
%ID
notation for route domains other than route domain
0
, the Source Hosts and Networks
and
Destination Hosts and Networks
settings for packet filter rules accept IP
addresses without the %ID
route domain notation. This is because when you
apply the packet filter rule to a VLAN, which belongs to a route domain, you are indirectly
specifying which route domain’s traffic to filter.Packet filter rules are unrelated to iRules®
You can also configure global packet filtering that applies to all packet filter rules that you create.
