Manual Chapter :
Order of packet filter rules
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
You use the
Order
setting to specify the order in which you want the BIG-IP® system to apply existing packet filter rules. This setting is required.
Possible values for this setting are:- First
- Select this value if you want this packet filter rule to be the first rule that the BIG-IP system applies.
- Last
- Select this value if you want this packet filter rule to be the last rule that the BIG-IP system applies.
- After
- Select this value, and then select a packet filter rule from the list, if you want the system to apply this packet filter after the packet filter that you select from the list. Note that this setting is most useful when you have more than three packet filter rules configured.
