Manual Chapter :
Rate class assignment
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
Using the
Rate Class
setting, you can assign a rate class to traffic
that matches the criteria defined in a packet filter rule. Note that this setting applies only
when you have the rate shaping feature enabled.The default value for this setting is None. If you previously created rate classes using the
rate shaping feature, you can choose one of those rate classes from the
Rate
Class
list.
