Manual Chapter :
About Single Rate Three Color Marker Policers
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
A
Single Rate Three Color Marker (srTCM) policer
meters an IP packet stream
and classifies the packets as either green, yellow, or red. An srTCM policer is useful, for
example, for ingress policing of a service, where only the length, not the peak rate, of the
burst determines service eligibility.The srTCM color classification is based on specific values that you define:
- Committed Information Rate (CIR)
- This is the rate, in bytes per second, that you want the BIG-IP® system to commit to the guest. For packets that are part of a flow consuming less than or equal to the CIR value, the system classifies the packets asgreen.
- Committed Burst Size (CBS)
- This is a burst size, in bytes, that you want the system to commit to the guest beyond the CIR value. For packets that are part of a burst into the allocated CBS value, the system classifies the packets asyellow.
- Excess Burst Size (EBS)
- This is a data burst size, in bytes, that exceeds the CIR and CBS values and that you want the system to classify as excessive. For packets that are part of a burst into the specified EBS value, the system classifies the packets asredand might drop them.
In general, when you configure an srTCM policer, the BIG-IP system classifies a packet as
green
if the packet size does not exceed the CBS, yellow
if
the packet size exceeds the CBS but not the EBS, and red
otherwise.SrTCM policers that you create run in color-blind mode only. In
color-blind
mode, the policer ignores any color classifications that might have
been previously set on IP packets coming into the BIG-IP system.
