Manual Chapter :
About default route
domains for administrative partitions
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
About default route
The route domains feature includes the concept of default route domains, to
minimize the need for you to specify the %ID notation. When you designate a route domain as the
in a partition, any BIG-IP system
objects in that partition that do not include the %ID notation in their IP addresses are
automatically associated with the default route domain.The default route domain
for partition Common
The BIG-IP system, by default, includes one route domain, named route
domain
0
. Route domain 0
is known as the default route domain
on the BIG-IP system, and this route domain resides in
administrative partition Common
. If
you do not create any other route domains on the system, all traffic automatically pertains to
route domain 0
.If you want to segment traffic into multiple route domains, you can create
additional route domains in partition
Common
and then segment application traffic among those route domains. Any BIG-IP
addresses that do not include the route domain ID notation are automatically associated with the
default route domain.Any VLANs
that reside in partition
Common
are
automatically assigned to the default route domain.The default route domain
for other partitions
For administrative partitions other than
Common
, you can create a route domain and
designate it as a partition default route domain
. A partition
can contain one partition default route domain only.The benefit of having a partition default route domain is that when you
create objects such as a virtual server and pool members within that partition, you do not need
to specify the ID of that default route domain within the addresses for those objects. For
example, if you create a partition default route domain with an ID of
2
in partition A
, the system automatically assigns any
partition A
object IP addresses
without a route domain ID to route domain 2
.If no partition default route domain exists within the partition, the
system associates those addresses with route domain
0
in partition Common
