Manual Chapter :
About VLAN and tunnel assignments for a route domain
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
You can assign one or more VLANs, VLAN groups, or tunnels to a route domain. The VLANs, VLAN
groups, or tunnels that you assign to a route domain are those pertaining to the particular
traffic that you want to isolate in that route domain. Each VLAN, VLAN group, or tunnel can be a
member of one route domain only.
When you assign a VLAN group to a route domain, the BIG-IP system automatically assigns the VLAN group members to the route domain.
Please note the following facts:
- If you delete a VLAN group from the system, the VLAN group members remain assigned to the route domain.
- If a VLAN is assigned to a non-default route domain and you delete that route domain, the BIG-IP system automatically assigns the VLAN to the default route domain for that partition.
- When you create VLANs, VLAN groups, and tunnels, the BIG-IP system automatically assigns them to the default route domain of the current partition. You can change this assignment when you create other route domains in the partition.
You cannot assign a VLAN that resides in partition
Common
to a route domain in another partition.
