Manual Chapter :
Self IP addresses for SNATs
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
When you configure the BIG-IP® system to manage local area traffic, you
can implement a feature known as a secure network address translation (SNAT). A
SNAT
is an object that causes the BIG-IP system to translate the original source IP address of a
packet to an IP address that you specify. A SNAT ensures that the target server sends its
response back through the BIG-IP system rather than to the original client IP address
directly.When you create a SNAT, you can configure the BIG-IP system to automatically choose a
translation address. This ability of the BIG-IP system to automatically choose a translation
address is known as
SNAT automapping
, and in this case, the translation address that
the system chooses is always an existing self IP address. Thus, for traffic going from the BIG-IP
system to a destination server, configuring SNAT automapping ensures that the source IP address
in the header of a packet is a self IP address.When you create an automapped SNAT, the BIG-IP system actually creates a SNAT pool consisting of the system’s internal self IP addresses, and then uses an algorithm to select and assign an address from that SNAT pool.
