Manual Chapter :
Static route management on the BIG-IP system
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
Part of managing routing on a BIG-IP® system is to add static routes for
destinations that are not located on the directly-connected network. If you are using the route
domains feature, you can specify a route domain ID as part of each IP address that you include in
a static route entry.
