Manual Chapter : Create a pool of web servers
Applies To:
Show Versions Show Versions
BIG-IP LTM
  • 15.1.10, 15.1.9, 15.1.8, 15.1.7, 15.1.6, 15.1.5, 15.1.4, 15.1.3, 15.1.2, 15.1.1, 15.1.0
Manual Chapter
Use this procedure to create a pool of servers for serving web application traffic.
  1. On the Main tab, click
    Local Traffic
    Pools
    The Pool List screen opens.
  2. Click
    Create
    The New Pool screen opens.
  3. In the
    Name
    field, type a unique name for the pool.
  4. Using the
    New Members
    setting, add each resource that you want to include in the pool:
    1. Select
      Node List
    2. For the
      Address
      option, select the IP address of the web application server.
    3. For the
      Service Port
      option, select HTTPS from the list.
    4. Click
      Add
      The added pool member appears in the displayed table.
    5. Repeat the process until all pool members are added.
  5. Click
    Finished
The new pool appears in the Pools list.
