Manual Chapter :
How step-up
authentication works
Applies To:
Show VersionsBIG-IP APM
- 15.0.1, 15.0.0
How step-up
1 | User logs in and authenticates through a per-session
policy; Access Policy Manager (APM) creates a session. User starts to use an
application that's available in the enterprise. User can access all but two parts of
the application that APM protects with step-up authentication, which requires:
2 | User requests access to part of the application protected
with step-up authentication (username and password). APM challenges the user and then
starts a subsession; for simplicity, we call it Subsession 1. For the duration of
Subsession 1: If the user passed step-up authentication, the user does not need to
authenticate again to access that part of the application; If the user failed step-up
authentication, the user does not have access and step-up authentication does not run
again. |
3 | User requests access to part of the application protected with step-up
authentication certificate authentication. APM challenges the user and
then starts another subsession, Subsession 2. If the user passes
certificate authentication, for the duration of Subsession 2: If the
failed step-up authentication, the user does not have access and step-up
authentication does not run again. A subsession ends when its lifetime expires
or when the session ends, whichever is sooner. |
