Manual Chapter :
Example: Step-up auth on move from wired to wireless
Applies To:
Show Versions
BIG-IP APM
- 15.0.1, 15.0.0
This example shows using gating criteria to check whether a request in a
subsession is coming from the same IP address. It uses two subroutines: AD Authentication and
MFA. AD Authentication specifies
perflow.client.ip.address
as the gating criteria. The user must authenticate using
first factor credentials if the IP address has changed, for example, if the user has switched
from the wired network to using wireless. In that case, if initial authentication is successful, request is routed to
the MFA subroutine for step-up authentication. The gating criteria for MFA is
expr {[mcget
{session.adStepUpAuth.gatingCounterPath}]}
, where the session variable session.adStepUpAuth.gatingCounterPath
was populated in
the AD Authentication subroutine. The example ties the two subroutines together: as soon as the
first subroutine is reevaluated, the second must be reevaluated again.
