Manual Chapter : Configuring High-Speed Remote Logging of SIP DoS Events
Applies To:
Show Versions Show Versions
BIG-IP AFM
  • 15.0.1, 15.0.0
Manual Chapter
Overview: Configuring SIP DoS Protection event logging
You can configure the BIG-IP system to log information about BIG-IP system SIP protocol denial-of-service (DoS) events, and send the log messages to remote high-speed log servers.
The Advanced Firewall Manager (AFM) must be licensed and provisioned before you can configure SIP DoS Protection event logging. Additionally, for high volume logging requirements, such as DoS, ensure that the BIG-IP system sends the event logs to a remote log server.
When configuring remote high-speed logging of DoS Protection event logging, it is helpful to understand the objects you need to create and why, as described here:
Object
Reason
Pool of remote log servers
Create a pool of remote log servers to which the BIG-IP system can send log messages.
Destination (unformatted)
Create a log destination of Remote High-Speed Log type that specifies a pool of remote log servers.
Destination (formatted)
If your remote log servers are the ArcSight, Splunk, IPFIX, or Remote Syslog type, create an additional log destination to format the logs in the required format and forward the logs to a remote high-speed log destination.
Publisher
Create a log publisher to send logs to a set of specified log destinations.
Logging profile
Create a custom Logging profile to enable logging of user-specified data at a user-specified level, and associate a log publisher with the profile.
LTM virtual server
Associate a custom Logging profile with a virtual server to define how the BIG-IP system logs security events on the traffic that the virtual server processes.
This illustration shows the association of the configuration objects for remote high-speed logging of DoS Protection events.
Association of remote high-speed logging configuration objects
Associations between remote high-speed logging configuration objects
Task summary for configuring SIP DoS protection event logging
Perform these tasks to configure logging of SIP DoS Protection events on the BIG-IP system.
Enabling logging impacts BIG-IP system performance.
Create a pool of remote logging servers
Before creating a pool of log servers, gather the IP addresses of the servers that you want to include in the pool. Ensure that the remote log servers are configured to listen to and receive log messages from the BIG-IP system.
  1. On the Main tab, click
    Local Traffic
    Pools
    The Pool List screen opens.
  2. Click
    Create
    The New Pool screen opens.
  3. In the
    Name
    field, type a unique name for the pool.
  4. Using the
    New Members
    setting, add the IP address for each remote logging server that you want to include in the pool:
    1. Type an IP address in the
      Address
      field, or select a node address from the
      Node List
    2. Type a service number in the
      Service Port
      field, or select a service name from the list.
      Typical remote logging servers require port
      514
    3. Click
      Add
  5. Click
    Finished
Create a remote high-speed log destination
Before creating a remote high-speed log destination, ensure that at least one pool of remote log servers exists on the BIG-IP system.
Create a log destination of the
type to specify that log messages are sent to a pool of remote log servers.
    System
    Logs
    Configuration
    Log Destinations
    The Log Destinations screen opens.
  2. Click
    Create
  3. In the
    Name
    field, type a unique, identifiable name for this destination.
  4. From the
    Type
    list, select
    If you use log servers such as Remote Syslog, Splunk, or ArcSight, which require data be sent to the servers in a specific format, you must create an additional log destination of the required type, and associate it with a log destination of the
    type. With this configuration, the BIG-IP system can send data to the servers in the required format.
    The BIG-IP system is configured to send an unformatted string of text to the log servers.
  5. From the
    Pool Name
    list, select the pool of remote log servers to which you want the BIG-IP system to send log messages.
  6. From the
    Protocol
    list, select the protocol used by the high-speed logging pool members.
  7. Click
    Finished
Create a formatted remote high-speed log destination
Ensure that at least one remote high-speed log destination exists on the BIG-IP system.
Create a formatted logging destination to specify that log messages are sent to a pool of remote log servers, such as Remote Syslog, Splunk, or IPFIX servers.
    System
    Logs
    Configuration
    Log Destinations
  2. Click
    Create
  3. In the
    Name
  4. From the
    Type
    list, select a formatted logging destination, such as
    Remote Syslog
    Splunk
    , or
    IPFIX
    The Splunk format is a predefined format of key value pairs.
    The BIG-IP system is configured to send a formatted string of text to the log servers.
  5. If you selected
    Remote Syslog
    , then from the
    Syslog Format
    list select a format for the logs, and then from the
    High-Speed Log Destination
    list, select the destination that points to a pool of remote Syslog servers to which you want the BIG-IP system to send log messages.
    For logs coming from Access Policy Manager (APM), only the BSD Syslog format is supported.
  6. If you selected
    Splunk
    or
    IPFIX
    , then from the
    Forward To
    list, select the destination that points to a pool of high-speed log servers to which you want the BIG-IP system to send log messages.
  7. Click
    Finished
Create a publisher
Ensure that at least one destination associated with a pool of remote log servers exists on the BIG-IP system.
Create a publisher to specify where the BIG-IP system sends log messages for specific resources.
    System
    Logs
    Configuration
    Log Publishers
    The Log Publishers screen opens.
  2. Click
    Create
  3. In the
    Name
    field, type a unique, identifiable name for this publisher.
  4. For the
    Destinations
    setting, select a destination from the
    Available
    list, and click
    to move the destination to the
    Selected
    list.
    If you are using a formatted destination, select the destination that matches your log servers, such as Remote Syslog, Splunk, or ArcSight.
  5. Click
    Finished
Create a custom SIP DoS protection logging profile
Create a custom logging profile to log SIP DoS Protection events and send the log messages to a specific location.
    Security
    Event Logs
    Logging Profiles
    The Logging Profiles list screen opens.
  2. Click
    Create
    The Create New Logging Profile screen opens.
  3. In the Logging Profile Properties, select the
    DoS Protection
    check box.
    The DoS Protection tab opens.
  4. In the SIP DoS Protection area, from the
    Publisher
    list, select the publisher that the BIG-IP system uses to log SIP DoS events.
    You can specify publishers for other DoS types in the same profile, for example, for DNS or Application DoS Protection.
  5. Click
    Create
Assign this SIP DoS Protection logging profile to a protected object.
Logging DoS/DDoS Events for a Protected Object
Assign a logging profile to a protected object when you want the system to log DoS events.
    Security
    DoS Protection
    Protected Objects
  2. Click the name of the protected object for which you want to log DoS events.
    The Properties pane opens on the right.
  3. In the Network & General area, for
    Logging Profiles
    , move the logging profile to assign from the Available list into the Selected list.
    You can create, and modify log publishers in
    System
    Logs
    Configuration
    Log Publishers
  4. Click
    Save
The system logs DoS events for the protected object.
You can review DoS event logs at
Security
Event Logs
DoS
and select the type of DoS event log to view.
Implementation result
The BIG-IP system logs specific DoS Protection events and sends the logs to a specific location.
