Manual Chapter : Modify multiple attack vectors at once
Applies To:
Show Versions Show Versions
BIG-IP AFM
  • 15.0.0
Manual Chapter
You can modify the State and Threshold Mode of multiple attack vectors protecting the device at one time.
  1. On the Main tab, click
    Security
    Dos Protection
    Device Protection
  2. Click the
    Network
    DNS
    , or
    SIP
    area at the bottom of the page.
    All of the attack vectors for that familiy appear in the Attack Type list.
  3. To modify the state of one or more attack vectors, click the check box next to each attack vector name.
  4. From the
    Set State
    list at the bottom of the page, select
    Disable
    Learn Only
    Mitigate
    Detect Only
    , or
    Mitigate
  5. Click
    Commit Changes to System
    at the top of the page.
  6. To modify the threshold mode of one or more attack vectors, click the check box next to each attack vector name.
  7. From the
    Set Threshold Mode
    Fully Automatic
    Manual Detection / Auto Mitigation
    , or
    Manual
    To work accurately, using fully-automatic thresholds requires some amount of historical data on the system gathered through observing normal traffic. Therefore, it is recommended that you not enforce auto thresholds directly after installation.
  8. Click
You have modified the attack vector State and Threshold Mode of multiple attack vectors.
