Manual Chapter : Create an eviction policy
Applies To:
Show Versions Show Versions
BIG-IP AFM
  • 15.0.0
Manual Chapter
You can create eviction policies to control the granularity and aggressiveness with which the system discards flows.
  1. On the Main tab, click
    DoS Configuration
    Eviction Policy
  2. Click
    Create
    The
    New Eviction Policy
    screen opens.
  3. In the
    Name
    field, type a name for the eviction policy.
  4. In the
    Trigger
    fields, type a high and low water mark for the eviction policy.
    This measure specifies the percentage of the quota, for this context, before flow eviction starts (high water mark) and ends (low water mark).
  5. Enable
    Slow Flow Monitoring
    to monitor flows that are considered slow by the system, and specify the slow flow threshold in bytes per second.
    This combination of settings monitors the system for flows that fall below the slow flow threshold for more than 30 seconds.
  6. In the
    Grace Period
    field you can set a grace period, in seconds, between the detection of slow flows that meet the threshold requirement, and purging of slow flows according to the
    Slow Flow Throttling
    settings.
  7. In the Slow Flow Throttling area, set the slow flow throttling options.
    Disabled
    Slow flows are monitored, but not removed from the system when the threshold requirement is met for 30 seconds.
    Absolute
    Slow flows are removed from the system when the threshold requirement is met for 30 seconds. Setting an absolute limit removes all slow flows beyond the specified absolute number of flows.
    Percent
    Slow flows are removed from the system when the threshold requirement is met for 30 seconds. Setting a percentage limit removes that percentage of slow flows that exceed the specified monitoring setting, so the default value of 100% removes all slow flows that exceed the slow flow threshold, after the grace period.
  8. For
    Strategies
    , configure the strategies that the eviction policy uses to remove flows by moving algorithms from the
    Available
    list to the
    Selected
    list.
  9. Click
    Finished
The eviction policy appears in the Eviction Policy List.
To use an eviction policy, associate it with a protected object or a route domain. You can configure a global eviction policy at
System
Configuration
Local Traffic
General
