Manual Chapter : Limit connections and flows on a route domain
Applies To:
Show Versions Show Versions
BIG-IP AFM
  • 15.0.1, 15.0.0
Manual Chapter
Before performing this task, confirm that you have a configured route domain, or use the common route domain
0
. You must add VLANs to a route domain for the route domain to effect traffic.
Assign connection limits and an eviction policy to a route domain to enact granular control over possible attacks or overflows on system flows.
  1. On the Main tab, click
    Network
    Route Domains
    The Route Domain List screen opens.
  2. In the Name column, click the name of the relevant route domain.
  3. In the
    Connection Limit
    field, type the maximum number of concurrent connections allowed for the route domain. Setting this to
    0
    turns off connection limits. The default is
    0
  4. From the
    Eviction Policy
    list, select an eviction policy to apply to this route domain.
  5. Click
    Update
    The system displays the list of route domains on the BIG-IP system.
The route domain now applies the connection limit and eviction policy to flows and connections.
