Manual Chapter : Managing Client-Side HTTP Traffic Using a CA-Signed Elliptic Curve DSA Certificate
Applies To:
  • BIG-IP AAM
    15.0.1, 15.0.0
  • BIG-IP APM
    15.0.1, 15.0.0
  • BIG-IP Link Controller
    15.0.1, 15.0.0
  • BIG-IP Analytics
    15.0.1, 15.0.0
  • BIG-IP LTM
    15.0.1, 15.0.0
  • BIG-IP AFM
    15.0.1, 15.0.0
  • BIG-IP PEM
    15.0.1, 15.0.0
  • BIG-IP DNS
    15.0.1, 15.0.0
  • BIG-IP ASM
    15.0.1, 15.0.0
When you configure the BIG-IP system to decrypt client-side HTTP requests and encrypt the server responses, you can optionally configure the BIG-IP system to use the Elliptic Curve Digital Signature Algorithm (ECDSA) as part of the BIG-IP system’s certificate key chain. The result is that the BIG-IP system performs the SSL handshake usually performed by target web servers, using an ECDSA key type in the certificate key chain.
This particular implementation uses a certificate signed by a certificate authority (CA).
To implement client-side and server-side authentication using HTTP and SSL with a CA-signed certificate, you perform a few basic configuration tasks.
You can generate a certificate that includes an Elliptic Curve Digital Signature Algorithm (ECDSA) key type, and then copy it or submit it to a trusted certificate authority for signature.
  1. On the Main tab, click System > Certificate Management > Traffic Certificate Management.
    The Traffic Certificate Management screen opens.
  2. Click Create.
  3. In the Name field, type a unique name for the SSL certificate.
  4. From the Issuer list, select Certificate Authority.
  5. In the Common Name field, type a name.
    This is typically the name of a web site, such as www.siterequest.com.
  6. In the Division field, type your department name.
  7. In the Organization field, type your company name.
  8. In the Locality field, type your city name.
  9. In the or State or Province field, type your state or province name.
  10. From the Country list, select the name of your country.
  11. In the E-mail Address field, type your email address.
  12. In the Lifetime field, type a number of days, or retain the default, 365.
  13. In the Subject Alternative Name field, type a name.
    This name is embedded in the certificate for X509 extension purposes.
    By assigning this name, you can protect multiple host names with a single SSL certificate.
  14. In the Challenge Password field, type a password.
  15. In the Confirm Password field, re-type the password you typed in the Challenge Password field.
  16. From the Key Type list, select ECDSA.
  17. From the Curve list, select an elliptic curve:
prime256v1
Creates a key that is 256 bits in length
secp384r1
Creates a key that is 384 bits in length
secp521r1
Creates a key that is 521 bits in length
**Note:** In general, longer keys can impact performance but are more secure. Shorter keys result in better performance but are less secure.
  1. Do one of the following to download the request into a file on your system.
    • In the Request Text field, copy the certificate.
    • For Request File, click the button.
  2. Follow the instructions on the relevant certificate authority web site for either pasting the copied request or attaching the generated request file.
  3. Click Finished.
    The Certificate Signing Request screen displays.
The generated certificate is submitted to a trusted certificate authority for signature.
An HTTP profile defines the way that you want the BIG-IPsystem to manage HTTP traffic.
  1. On the Main tab, click Local Traffic > Profiles > Services > HTTP.
    The HTTP profile list screen opens.
  2. Click Create.
    The New HTTP Profile screen opens.
  3. In the Name field, type a unique name for the profile.
  4. From the Parent Profile list, select http.
  5. Select the Custom check box.
  6. Modify the settings, as required.
  7. Click Finished.
The custom HTTP profile now appears in the HTTP profile list screen.
You create a custom Client SSL profile when you want the BIG-IP system to terminate client-side SSL traffic for the purpose of:
  • Authenticating and decrypting ingress client-side SSL traffic
  • Re-encrypting egress client-side traffic
By terminating client-side SSL traffic, the BIG-IP system offloads these authentication and decryption/encryption functions from the destination server.
  1. On the Main tab, click Local Traffic > Profiles > SSL > Client.
    The Client SSL profile list screen opens.
  2. Click Create.
    The New Client SSL Profile screen opens.
  4. Select clientssl in the Parent Profile list.
  5. From the Configuration list, select Advanced.
  6. Select the Custom check box.
    The settings become available for change.
  7. Next to Client Authentication, select the Custom check box.
    The settings become available.
  8. From the Configuration list, select Advanced.
  9. Modify the settings, as required.
  10. Click Finished.
You can create a pool of web servers to process HTTP requests.
  1. On the Main tab, click Local Traffic > Pools.
    The Pool List screen opens.
  2. Click Create.
    The New Pool screen opens.
  3. In the Name field, type a unique name for the pool.
  4. For the Health Monitors setting, from the Available list, select the http monitor and move the monitor to the Active list.
  5. From the Load Balancing Method list, select how the system distributes traffic to members of this pool.
    The default is Round Robin.
  6. For the Priority Group Activation setting, specify how to handle priority groups:
    • Select Disabled to disable priority groups. This is the default option.
    • Select Less than, and in the Available Members field type the minimum number of members that must remain available in each priority group in order for traffic to remain confined to that group.
  7. Using the New Members setting, add each resource that you want to include in the pool:
    1. Type an IP address in the Address field.
    2. Type 80 in the Service Port field, or select HTTP from the list.
    3. (Optional) Type a priority number in the Priority field.
    4. Click Add.
  8. Click Finished.
The new pool appears in the Pools list.
You can specify a virtual server to be either a host virtual server or a network virtual server to manage HTTP traffic over SSL.
  1. On the Main tab, click Local Traffic > Virtual Servers.
    The Virtual Server List screen opens.
  2. Click Create.
    The New Virtual Server screen opens.
  3. In the Name field, type a unique name for the virtual server.
  4. For the Destination Address/Mask setting, confirm that the Host button is selected, and type the IP address in CIDR format.
    The supported format is address/prefix, where the prefix length is in bits. For example, an IPv4 address/prefix is 10.0.0.1 or 10.0.0.0/24, and an IPv6 address/prefix is ffe1::0020/64 or 2001:ed8:77b5:2:10:10:100:42/64. When you use an IPv4 address without specifying a prefix, the BIG-IP system automatically uses a /32 prefix.
    Note: The IP address you type must be available and not in the loopback network.
  5. In the Service Port field, type 443, or select HTTPS from the list.
  6. From the HTTP Profile list, select the HTTP profile that you previously created.
  7. For the SSL Profile (Client) setting, from the Available list, select the name of the Client SSL profile you previously created and move the name to the Selected list.
  8. In the Resources area, from the Default Pool list, select the name of the pool that you created previously.
  9. Click Finished.
After performing this task, the virtual server appears in the Virtual Server List screen.
After you complete the tasks in this implementation, the BIG-IP system encrypts client-side ingress HTTP traffic using an SSL certificate key chain. The BIG-IP system also re-encrypts server responses before sending the responses back to the client.
The certificate in the certificate key chain includes an Elliptic Curve Digital Signature Algorithm (ECDSA) key and certificate.
