Updated Date: 07/07/2026
Tools for Geo-Redundancy
Access the following tools from the BIG-IP CLI:
- bigstart: For control and status check on the daemons/process (TMM, Kafka, ZooKeeper, MirrorMaker).
- diadb: To display and delete Diameter persistence entries.
gepdb: To display the status of Geo-redundancy setup, enforce manual reload, and display Geo-Redundancy iRule tables.
Usage: geodb [options]
-r, --reload
manually trigger a georedundancy reload
this device will become reload_receiving
-s, --status output a single word status
e.g. "connected"
-i, --irules lists all entries in iRule session table in raw format
-c, --count show persistance record count
-w, --watchdog show watchdog monitor status
e.g. "alive" or "expired" Possible geodb states
unset/offiline: Geo-redundancy is not initialized or not enabledconnected: In sync with remote sitereload_receiving: Waiting for reload data from remote sitereload_sending: Sending reload data to remote sitestandalone: Reload timeout has expired, running standalone
Possible geodb watchdog output
unset: Geo-redundancy is not initialized or not enabledalive: Received watchdog keep alive from remote site within allocated watchdog periodexpired: Watchdog timeout expired
Kafka includes a number of tools for maintenance and administration of a Kafka cluster as part of the open source project. Under normal circumstances, these tools are not required, but can be useful for troubleshooting as a last resort.
Important: Modifying Kafka configs generated by iAppLX is not recommended.
By default, JAVA_HOME is not configured on a BIG-IP; set it before using any of the Kafka tools.
Topic and consumer group are configured in the Geo-Redundancy profile.
Note: Each BIG-IP maintains its own Kafka cluster, so output will likely be different on each BIG-IP.
The scripts below are located in /usr/bin/kafka/bin/. For more information: https://kafka.apache.org/quickstart.
Set
JAVA_HOME:# export JAVA_HOME="/usr/java/java-1.7.0-openjdk" -
List created topics:
# /usr/bin/kafka/bin/kafka-topics.sh --list --zookeeper localhost:2181 -
Check topic status:
# /usr/bin/kafka/bin/kafka-topics.sh --describe --zookeeper localhost:2181 --topic <topic> -
Checking consumers offset:
# /usr/bin/kafka/bin/kafka-consumer-groups.sh --bootstrap-server localhost:9192 --group <group> --describe -
Producing test Kafka records:
# /usr/bin/kafka/bin/kafka-console-producer.sh --broker-list localhost:9192 --topic <topic> -
Consuming Kafka records:
# /usr/bin/kafka/bin/kafka-console-consumer.sh --bootstrap-server localhost:9192 --topic <topic>
