Manual Chapter : Create a virtual server for web traffic over QUIC
Applies To:
Show Versions Show Versions
BIG-IP LTM
  • 15.1.0
Manual Chapter
You can create a virtual server on the BIG-IP system to manage web traffic that uses the transport-layer protocol QUIC instead of TCP. Once deployed, this virtual server causes the system to: listen for secure client web traffic sent over QUIC and UDP, decrypt the traffic, and forward the decrypted traffic to an application server pool over TCP.
  1. On the Main tab, click
    Local Traffic
    Virtual Servers
    This displays a list of virtual servers on the system.
  2. Click
    Create
  3. Type a name for the virtual server, such as
    my_vs_quic
  4. From the
    Type
    list, select
    Standard
  5. In the
    Source Address
    box, confirm that
    Host
    is selected, and type the address
    0.0.0.0
  6. In the
    Destination Address/Mask
    box, confirm that
    Host
    is selected, and type an IP address in CIDR format.
    The netmask you specify must be
    /32
    (that is,
    255.255.255.255
  7. From the
    Service Port
    list, select
    HTTPS
  8. From the
    State
    list, confirm that
    Enabled
    is selected.
  9. From the
    Configuration
    list, select
    Advanced
  10. From the
    Protocol
    list, select
    UDP
  11. From the
    Protocol Profile (Client)
    list, confirm that
    udp
    is selected.
  12. From the
    Protocol Profile (Server)
    list, select an existing TCP profile.
    F5 recommends that you select the default profile
    f5-tcp-lan
  13. For the
    HTTP Profile (Client)
    setting, confirm that the default profile
    http
    is selected.
  14. For the
    HTTP Profile (Server)
    (Use Client Profile)
    is selected.
  15. For the
    SSL Profile (Client)
    setting, select
    clientssl-quic
  16. From the
    Source Address Translation
    list, select
    Auto Map
  17. For the
    Address Translation
    Enabled
    check box is selected.
  18. For the
    Port Translation
    Enabled
  19. In the Acceleration area of the screen, for the
    HTTP MRF Router
    setting, select the check box.
  20. For the
    QUIC Profile
    setting, select the QUIC profile that you previously created.
  21. From the
    HTTP3 Profile
    list, select the HTTP3 profile you previously created.
  22. From the
    Default Pool
    list, select the name of the web server pool you created earlier.
  23. Click
    Finished
