Manual Chapter : Perflow and subsession variables
Applies To:
  • BIG-IP APM
    15.1.8, 15.1.7, 15.1.6, 15.1.5, 15.1.4, 15.1.3, 15.1.2, 15.1.1, 15.1.0
Perflow variables exist only while a per-request policy runs. Perflow variables for a per-request policy subroutine exist while the subsession exists. Multiple subsessions can run simultaneously. The table lists perflow variables and their values.
Name Value, if known
perflow.ad.last.authresult Last authentication result.
perflow.agent_category_lookup.type Agent category type.
perflow.agent_ending.result 0 (success) or 1 (failure).
perflow.agent_failed.reason Reason for agent failure.
perflow.agent_license.status Status of the agent license.
perflow.agent_license.type Type of agent license.
perflow.agent.state Agent state.
perflow.api.api_server Set by the Request Classification agent when the matching path is associated with a server. Also set by the API Server Selection agent.
perflow.api.traffic_key.user_id API traffic user ID.
perflow.api.traffic_key.user_group_id API traffic user group ID.
perflow.api.traffic_key.client_app_id API traffic client application ID.
perflow.api.traffic_key.service_tier API traffic service tier.
perflow.api.traffic_key.organization_id API traffic organization ID.
perflow.api_rate_limiting.error_string Set by the API Rate Limiting Enforcement agent if an error occurred.
perflow.api.proxy_error API proxy error.
perflow.api.proxy_auth_type API proxy authorization type.
perflow.api_rate_limiting.result Set by the API Rate Limiting Enforcement agent indicating whether enforcement succeeded.
perflow.apmd_agent.state APM daemon state.
perflow.application_filter_lookup.result.action 0 (reject) or 1 (allow).
perflow.application_lookup.result.effective_ application Name of the application that is ultimately used.
perflow.application_lookup.result.effective_ family Name of the application family that is ultimately used.
perflow.application_lookup.result.families Comma-separated list of application families.
perflow.application_lookup.result.names Comma-separated list of application names.
perflow.application_lookup.result.primary_ application Name of the application that APM determines is the primary one.
perflow.application_lookup.result.primary_family Name of the application family that Access Policy Manager (APM) determines is the primary one. (An application might fit into more than one application family.)
perflow.bypass_lookup.result.ssl SSL bypass lookup result.
perflow.assign_credentials.password Password from Assign Credentials agent.
perflow.assign_credentials.share_password Shared password from Assign Credentials agent.
perflow.assign_credentials.username Username from Assign Credentials agent.
perflow.branching.url Name of branching URL.
perflow.bypass_lookup.result.ssl 0 (http) or 1 (https).
perflow.category_lookup.failure 0 (success) or 1 (server failure).
perflow.category_lookup.result.categories Comma-separated list of categories.
perflow.category_lookup.result.custom categories Unique number that identifies a custom category; used internally.
perflow.category_lookup.result.display category Name of the display category.
perflow.category_lookup.result.effective_category Name of the category that is ultimately used.
perflow.category_lookup.result.filter_name Name of the URL filter.
perflow.category_lookup.result.hostname Host name retrieved from SSL input.
perflow.category_lookup.result.numcategories Integer. Total number of categories in the comma-separated list of categories.
perflow.category_lookup.result.numcustom categories Integer. Total number of custom categories in the comma-separated list of custom categories.
perflow.category_lookup.result.primarycategory Name of the category that APM determines is the primary one. (A URL might fit into more than one category, such as news and sports.)
perflow.category_lookup.result.url Requested URL.
perflow.client.information.hash Client information.
perflow.client.information.header Client information header.
perflow.client.information.metadata.header Client information metadata header.
perflow.client.ip.address Client IP address.
perflow.client.port Client port number.
perflow.credential.block Credential block.
perflow.credential.blockkeys
perflow.custom Unique number that identifies a custom category; used internally.
perflow.custom.flow Custom flow.
perflow.decision_box.result 0 (continue) or 1 (cancel) selected for the Confirm Box action in the subroutine.
perflow.ending.redirect.captive.url Ending redirect captive portal URL.
perflow.epi.error_code End-point inspection error code.
perflow.epi.result End-point inspection result.
perflow.ip.geolocation.continent.result Continent based on geolocation of the IP address.
perflow.ip.geolocation.country.code.result Country code based on geolocation of the IP address.
perflow.ip.geolocation.country.name.result Country name based on geolocation of the IP address.
perflow.ip.geolocation.failure Geolocation failure.
perflow.ip.geolocation.region.result Region based on geolocation of the IP address.
perflow.ip.reputation.failure IP reputation failure.
perflow.ip.reputation.result IP reputation result.
perflow.irule_agent_id iRule agent ID.
perflow.l7_protocol_lookup.result Layer 7 protocol lookup result.
perflow.last.logon.itemname Last logon.
perflow.logon_save_user_credentials_ block Saved user credentials block.
perflow.mangled.url Name of mangled URL.
perflow.map.subroutine_subsession Subroutine subsession.
perflow.oauth.scope.auth_hdr_name OAuth scope header name.
perflow.oauth.scope.auth_hdr_value OAuth scope header value.
perflow.oauth.scope.status_code OAuth scope status codes.
perflow.oauth.scope.status_string OAuth scope status string.
perflow.on_demand_cert.result 0 (success) or 1 (failure) of On-Demand Certificate authentication in the subroutine.
perflow.on_demand_cert.orig_uri Originating URI of the On-Demand Certificate in the subroutine.
perflow.policy_path Policy path.
perflow.policy_path_count Policy path count.
perflow.protocol_lookup.result http or https. Defaults to https.
perflow.proxy_select.selection_reused Proxy select reuse.
perflow.redirect.url Redirect URL.
perflow.renderer.status_code Renderer status code.
perflow.renderer.status_code_from Where renderer status code is from.
perflow.renderer.status_code_to Where renderer status code is going to.
perflow.renderer.token Renderer token.
perflow.renderer.url Renderer URL.
perflow.request_analytics.failure 0 (success) or 1 (server failure).
perflow.request_classification.path_id Set by the Request Classification agent.
perflow.resource_assign_pool.name Pool name assigned.
perflow.response_analytics.failure 0 (success) or 1 (server failure).
perflow.response_header_names Response header names.
perflow.response_headers_num Response headers number.
perflow.response_headers_set Response headers set.
perflow.response_header_values Response header values.
perflow.response_selection.response Set by the Response Selection agent.
perflow.save.validated.credentials Validated credentials to save.
perflow.scratchpad Scratchpad.
perflow.scratchpad.flow Scratchpad flow.
perflow.service_path Service path.
perflow.session_check.session_found Session found during service check.
perflow.session.id Session ID.
perflow.server.ip.address Server IP address.
perflow.server.port Server port number.
perflow.ssl_bypass_set 0 (bypass) or 1 (intercept). SSL Bypass Set and SSL Intercept Set items update this value.
perflow.ssl.bypass_default 0 (bypass) or 1 (intercept). Specified in the client SSL profile, used when SSL Bypass Set and SSL Intercept Set items not included in per-request policy.
perflow.ssl_check.ssl_found SSL check found SSL.
perflow.ssl.client_cipher_name Client SSL cipher name.
perflow.ssl.client_cipher_version Client SSL cipher version.
perflow.ssl.server_cipher_name Server SSL cipher name.
perflow.ssl.server_cipher_version Server SSL cipher version.
perflow.ssl.server_cert.response_control Server SSL certificate response control.
perflow.ssl.server_cert.status Server SSL certificate status.
perflow.sso_configuration_select.name Single sign on configuration name.
perflow.subroutine.gating_expr Subroutine gating expression.
perflow.subroutine.invalidated 0 (validated) or 1 (invalidated) subroutine.
perflow.subroutine.loop_countdown Subroutine loop countbown.
perflow.subroutine.name Name of the subroutine.
perflow.subroutine.out_terminal Name of the subroutine out terminal.
perflow.subroutine_skip_agent_cb_flag Subroutine skip agent flag.
perflow.subsession.id Subsession ID.
perflow.subsession.lifetime Subsession length.
perflow.subsession.lookup Subsession lookup.
perflow.subsession.state Subsession state.
perflow.subsession.state_lookup Subsession state lookup.
perflow.swg_license.consume Secure Web Gateway consumer license.
perflow.swg_limited_license.consume Secure Web Gateway limited consumer license.
perflow.urlfilter_lookup.result.action 3 (confirm), 2 (block) or 1 (allow).
perflow.username User name.
perflow.subroutine.loop_countdown Number of iterations remaining on a subroutine loop.
subsession.logon.last.username User name for the last login.
subsession.logon.last.authtype Last authentication type
subsession.ad.last.actualdomain Domain name for the last login.
subsession.ad.last.authresult 0 (success) or 1 (failure) of Active Directory authentication in the subroutine.
subsession.ad.last.errmsg Displays the error message for the last login.
subsession.api_authentication.scheme Set by the API Authentication agent. Set to either basic or bearer based on the authentication header in the request.
subsession.ldap.last.authresult 0 (success) or 1 (failure) of LDAP authentication in the subroutine.
subsession.ldap.last.errmsg Displays the error message for the last login.
subsession.radius.last.attr.filter-id RADIUS attribute filter ID
subsession.radius.last.attr.framed-compression RADIUS attribute framed compression.
subsession.radius.last.attr.framed-mtu RADIUS attribute framed MTU.
subsession.radius.last.attr.framed-protocol RADIUS attribute framed protocol.
subsession.radius.last.attr.service-type RADIUS attribute service type.
subsession.radius.last.errmsg Displays the error message for the last login.
subsession.radius.last.result 0 (success) or 1 (failure) of RADIUS authentication in the subroutine.
