Manual Chapter :
Overview: Secure Vault administration
Applies To:
Show Versions
BIG-IP LTM
- 15.1.2, 15.1.0, 15.0.1, 15.0.0, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.3, 13.1.1, 13.1.0
BIG-IP DNS
The BIG-IP system's
Secure
Vault
feature provides an additional layer of security for BIG-IP
and BIG-IQ systems. This additional security allows you to encrypt passwords or
passphrases for individual BIG-IP configuration objects.The Secure Vault feature is in the form of a unit key and a
master key:
- Unit key
- Used to encrypt and decrypt the master key. Because a unit key protects the master key, unit keys must be safely stored, usually in electrically erasable programmable read-only memory (EEPROM), on hardware platforms that include EEPROM.
- Master key
- Used to encrypt and decrypt passwords and passphrases on individual configuration objects on the BIG-IP system, such as pools, health monitors, and SSL keys. The master key is stored in a file on the BIG-IP system.
On a BIG-IP system, encrypted passwords and passphrases for
BIG-IP configuration objects appear in the system configuration files and begin
with a $M$ prefix. For example:
passphrase $M$g2$UEOTKSvSN/7kasHTLIBsEw== password $M$Sx$z5wBus7I+VhvLCndYNz+Mg==
BIG-IP configuration file names include the
.conf
file extension, and
the system stores them in its /config
directory. The BIG-IP system secures access to
configuration files through user authentication.
