Manual Chapter :
About decryption errors
Applies To:
Show Versions
BIG-IP LTM
- 15.1.2, 15.1.0, 15.0.1, 15.0.0, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.3, 13.1.1, 13.1.0
BIG-IP DNS
When you attempt to restore a UCS archive or load a BIG-IP configuration that contains configuration object passwords or passphrases encrypted with a different master key, the operation fails and the system displays an error message that appears similar to one of the following examples:
0107102b:3: Master Key decrypt failure - decrypt failure - final 01071769:3: Decryption of the field (pvalue) for object (/Common/http_monitor_example 1 PASSWORD=) failed. 01071769:3: Decryption of the field (passphrase) for object (/Common/client_ssl_example example_encrypt) failed.
You might also encounter additional error messages such as the following:
01071027:5: Master key OpenSSL error: 1533808276:error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt:evp_enc.c:587: 01071769:3: Decryption of the field (privatekey) for object (9717) failed. 01070596:3: An unexpected failure has occurred, - sys/validation/MasterKey.cpp, line 4306, exiting..
