Manual Chapter : Create a listener for bi-directional traffic
Applies To:
  • BIG-IP LTM
    17.5.1, 17.5.0, 17.1.3, 17.1.2, 17.1.1, 17.1.0, 17.0.0, 16.1.6, 16.1.5, 16.1.4, 16.1.3, 16.1.2, 16.1.1, 16.1.0, 16.0.1, 16.0.0, 15.1.10, 15.1.9, 15.1.8, 15.1.7, 15.1.6, 15.1.5, 15.1.4, 15.1.3, 15.1.2, 15.1.1, 15.1.0, 15.0.1, 15.0.0, 14.1.5, 14.1.4, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0
You create a virtual server when you want the BIG-IP system to listen for client-side and server-side ingress traffic at Layer 2, without performing any packet modifications such as address translation.
  1. Log in to the BIG-IP Configuration utility using the system’s management IP address.
  2. On the Main tab, click Local Traffic > Virtual Servers.
    If your BIG-IP system user account restricts you to using TMSH (TMOS Shell) only, skip this step.
  3. Click Create.
  4. In the Name field, type a name, such as my_virtual_wire_vs.
  5. From the Type list, select Forwarding (Layer 2).
  6. In the Destination Address field, type the IP address in CIDR format. The supported format is address/prefix, where the prefix length is in bits. For example, an IPv4 address/prefix is 10.0.0.1 or 10.0.0.0/24, and an IPv6 address/prefix is ffe1::0020/64 or 2001:ed8:77b5:2:10:10:100:42/64. When you use an IPv4 address without specifying a prefix, the BIG-IP system automatically uses a /32 prefix.
  7. In the Service Port field, type a port number or select a service name from the Service Port list.
  8. From the VLAN and Tunnel Traffic list, select the name of the virtual wire you previously created.
  9. Click Finished.
