Updated Date: 07/07/2026
Preventing Device DoS/DDoS Attacks
BIG-IP devices are divided into three categories based on hardware capability, and each category allows the use of specific compatibility levels. When you modify the compatibility level of the system, you enable different levels of DoS/DDoS protection and whitelists that are available for use.
- Level 0
- Systems with basic hardware DoS capabilities. Provides device protection and Rich Whitelists. Valid for all systems, and is the default value.
- Level 1
- Virtual Edition (VE) systems or systems with hardware DoS and sPVA capabilities. Provides Level 0 features, per-virtual server DOS, whitelist hostaddress lists, IP Intelligence, and bad actor detection.
- Level 2
- Systems with hardware DoS, sPVA and Neuron capabilities. Provides Level 1 features, and whitelist subnet address lists.
Note: If using DDoS Hybrid Defender, adjusting the compatibility level must be done from the Advanced Menu.
On the Main tab, click System > Configuration > Device.
From the Compatibility Level list, select the appropriate compatibility level for your hardware.
You will receive a message if you select a level that is not applicable to your hardware.
Click Update.
The following tables, organized by DoS category, list AFM default device DoS attacks, and provide a short description and relevant information. You can adjust the thresholds in device protection by clicking the attack types and adjusting the properties.
| Vector | Information | Hardware accelerated |
| ARP Flood | ARP packet flood | Yes |
| Bad ICMP Checksum | An ICMP frame checksum is bad. Reuse the TCP or UDP checksum bits in the packet. | Yes |
| Bad ICMP Frame | The ICMP frame is either the wrong size or not one of the valid IPv4 or IPv6 types. | Yes |
| Bad IGMP Frame | IPv4 IGMP packets should have a header >= 8 bytes. Bits 7:0 should be either 0x11, 0x12, 0x16, 0x22 or 0x17, or else the header is bad. Bits 15:8 should be non-zero only if bits 7:0 are 0x11, or else the header is bad. | Yes |
| Bad IP TTL Value | Time-to-live equals zero for an IPv4 address. | Yes |
| Bad IP Version | The IPv4 address version in the IP header is not 4. | Yes |
| Bad IPv6 Addr | IPv6 source IP = 0xff00:: |
Yes |
| Bad IPV6 Hop Count | Both the terminated (cnt=0) and forwarding packet (cnt=1) counts are bad. | Yes |
| Bad IPV6 Version | The IPv6 address version in the IP header is not 6. | Yes |
| Bad SCTP Checksum | Bad SCTP packet checksum. | No |
| Bad Source | The IPv4 source IP = 255.255.255.255 or 0xe0000000U. |
Yes |
| Bad TCP Checksum | The TCP checksum does not match. | Yes |
| Bad TCP Flags (All Cleared) | Bad TCP flags (all cleared and SEQ#=0). | Yes |
| Bad TCP Flags (All Flags Set) | Bad TCP flags (all flags set). | Yes |
| Bad UDP Checksum | The UDP checksum is not correct. | Yes |
| Bad UDP Header (UDP Length > IP Length or L2 Length) | UDP length is greater than IP length or Layer 2 length. | Yes |
| Ethernet Broadcast Packet | Ethernet broadcast packet flood | Yes |
| Ethernet MAC Source Address == Destination Address | Ethernet MAC source address equals the destination address. | Yes |
| Ethernet Multicast Packet | Ethernet multicast packet flood | Yes |
| FIN Only Set | Bad TCP flags (only FIN is set). | Yes |
| Header Length > L2 Length | No room in Layer 2 packet for IP header (including options) for IPv4 address | Yes |
| Header Length Too Short | IPv4 header length is less than 20 bytes. | Yes |
| Host Unreachable | Host unreachable error | Yes |
| ICMP Fragment | ICMP fragment flood | Yes |
| ICMP Frame Too Large | The ICMP frame exceeds the declared IP data length or the maximum datagram length. To tune this value, in tmsh: modify sys db dos.maxicmpframesize value``, where value is <=65515. |
Yes |
| ICMPv4 Flood | Flood with ICMPv4 packets | Yes |
| ICMPv6 Flood | Flood with ICMPv6 packets | Yes |
| IGMP Flood | Flood with IGMP packets (IPv4 packets with IP protocol number 2) | Yes |
| IGMP Fragment Flood | Fragmented packet flood with IGMP protocol | Yes |
| IP Error Checksum | The header checksum is not correct. | Yes |
| IP Fragment Error | Other IPv4 fragment error | Yes |
| IP Fragment Flood | Fragmented packet flood with IPv4 | Yes |
| IP Fragment Overlap | IPv4 overlapping fragment error | No |
| IP Fragment Too Small | IPv4 short fragment error | Yes |
| IP Length > L2 Length | The total length in the IPv4 address header or payload length in the IPv6 address header is greater than the Layer 3 length in a Layer 2 packet. | Yes |
| IP Option Frames | IPv4 address packets that are part of an IP option frame flood. On the command line, option.db variable tm.acceptipsourceroute must be enabled to receive IP options. |
Yes |
| IP Option Illegal Length | Option present with illegal length. | No |
| IP uncommon proto | Sets thresholds for and tracks packets containing IP protocols considered to be uncommon. By default, all IP protocols other than TCP, UDP, ICMP, IPV6-ICMP, and SCTP are on the IP uncommon protocol list. | Yes |
| IP Unknown protocol | Unknown IP protocol | No |
| IPv4 mapped IPv6 | The IPv6 stack is receiving IPv4 address packets. | Yes |
| IPV6 Atomic Fragment | IPv6 Frag header present with M=0 and FragOffset =0. | Yes |
| IPv6 duplicate extension headers | An extension header should occur only once in an IPv6 packet, except for the Destination Options extension header. | Yes |
| IPv6 Extended Header Frames | IPv6 address contains extended header frames. | Yes |
| IPv6 extended headers wrong order | Extension headers in the IPv6 header are in the wrong order. | Yes |
| IPv6 extension header too large | An extension header is too large. To tune this value, in tmsh: modify sys db dos.maxipv6extsize value``, where value is 0-1024. |
Yes |
| IPv6 Fragment Error | Other IPv6 fragment error | Yes |
| IPv6 Fragment Flood | Fragmented packet flood with IPv6 | Yes |
| IPv6 Fragment Overlap | IPv6 overlapping fragment error | No |
| IPv6 Fragment Too Small | IPv6 short fragment error | Yes |
| IPv6 hop count <= <tunable> | The IPv6 extended header hop count is less than or equal to <tunable>. To tune this value, in tmsh: modify sys db dos.ipv6lowhopcnt value``, where value is 1-4. |
Yes |
| IPv6 Length > L2 Length | IPv6 address length is greater than the Layer 2 length. | Yes |
| L2 Length >> IP Length | Layer 2 packet length is much greater than the payload length in an IPv4 address header, and the Layer 2 length is greater than the minimum packet size. | Yes |
| LAND Attack | Source IP equals destination IP address | Yes |
| No L4 | No Layer 4 payload for IPv4 address. | Yes |
| No L4 (Extended Headers Go To Or Past End of Frame) | Extended headers go to the end or past the end of the L4 frame. | Yes |
| No Listener Match | This can occur if the listener is down as it attempts to make a connection, or if it was not started or was configured improperly. It may also be caused by a network connectivity problem. | |
| Non TCP Connection | Sets a connection rate limit for non-TCP flows that takes into account all other connections per second. | |
| Option Present With Illegal Length | Packets contain an option with an illegal length. | Yes |
| Payload Length < L2 Length | Specified IPv6 payload length is less than the L2 packet length. | Yes |
| Routing Header Type 0 | Identifies flood packets containing type 0 routing headers, which can be used to amplify traffic to initiate a DoS attack. | Yes |
| Single Endpoint Flood | Flood to a single endpoint and can come from many sources. You can configure packet types to check for, and packets per second for both detection and rate limiting. | No |
| Single Endpoint Sweep | Sweep on a single endpoint. You can configure packet types to check for, and packets per second for both detection and rate limiting. | No |
| SYN && FIN Set | Bad TCP flags (SYN and FIN set). | Yes |
| TCP BADACK Flood | TCP ACK packet flood | No |
| TCP Flags - Bad URG | Packet contains a bad URG flag; this is likely malicious. | Yes |
| TCP Half Open | TCP connection whose state is out of synchronization between the two communicating hosts | Yes |
| TCP Header Length > L2 Length | The TCP header length exceeds the Layer 2 length. | Yes |
| TCP Header Length Too Short (Length < 5) | The Data Offset value in the TCP header is less than five 32-bit words. | Yes |
| TCP Option Overruns TCP Header | The TCP option bits overrun the TCP header. | Yes |
| TCP PUSH Flood | TCP PUSH flood | Yes |
| TCP RST Flood | TCP RST flood | Yes |
| TCP SYN ACK Flood | TCP SYN/ACK flood | Yes |
| TCP SYN Flood | TCP SYN flood | Yes |
| TCP SYN Oversize | Detects TCP data SYN packets larger than the maximum specified by the dos.maxsynsize parameter. To tune this value in tmsh: modify sys db dos.maxsynsize value. The default size in bytes is 64 and the maximum allowable value is 9216. |
Yes |
| TCP Window Size | The TCP window size in packets is above the maximum size. To tune this value in tmsh: modify sys db dos.tcplowwindowsize value where value is <= 128. |
Yes |
| TIDCMP | ICMP source quench attack | Yes |
| Too Many Extension Headers | For an IPv6 address, there are too many extended headers (the default is 4). To tune this value in tmsh: modify sys db dos.maxipv6exthdrs value``, where value is 0-15. |
Yes |
| TTL <= <tunable> | An IP packet with a destination that is not multicast and that has a TTL greater than 0 and less than or equal to a tunable value, which is 1 by default. To tune this value, in tmsh: modify sys db dos.iplowttl value``, where value is 1-4. |
Yes |
| UDP Flood | UDP flood attack | Yes |
| Unknown Option Type | Unknown IP option type. | No |
| Unknown TCP Option Type | Unknown TCP option type. | Yes |
| DNS A Query | UDP packet, DNS Qtype is A_QRY, VLAN is <tunable>. To tune this value, in tmsh: modify sys db dos.dnsvlan value``, where value is 0-4094. |
Yes |
| DNS AAAA Query | UDP packet, DNS Qtype is AAAA, VLAN is <tunable>. To tune this value, in tmsh: modify sys db dos.dnsvlan value, where `value` is `0-4094`.. To tune this value, in tmsh: `modify sys db dos.dnsvlan `value, where value is 0-4094. |
Yes |
| DNS AXFR Query | UDP packet, DNS Qtype is AXFR, VLAN is <tunable>. To tune this value, in tmsh: modify sys db dos.dnsvlan value``, where value is 0-4094. |
Yes |
| DNS Any Query | UDP packet, DNS Qtype is ANY_QRY, VLAN is <tunable>. To tune this value, in tmsh: modify sys db dos.dnsvlan value``, where value is 0-4094. |
Yes |
| DNS CNAME Query | UDP DNS query, DNS Qtype is CNAME, VLAN is <tunable>. To tune this value, in tmsh: modify sys db dos.dnsvlan value``, where value is 0-4094. |
Yes |
| DNS IXFR Query | UDP DNS query, DNS Qtype is IXFR, VLAN is <tunable>. To tune this value, in tmsh: modify sys db dos.dnsvlan value``, where value is 0-4094. |
Yes |
| DNS MX Query | UDP DNS query, DNS Qtype is MX, VLAN is <tunable>. To tune this value, in tmsh: modify sys db dos.dnsvlan value``, where value is 0-4094. |
Yes |
| DNS Malformed | Malformed DNS packet | Yes |
| DNS NS Query | UDP DNS query, DNS Qtype is NS, VLAN is <tunable>. To tune this value, in tmsh: modify sys db dos.dnsvlan value``, where value is 0-4094. |
Yes |
| DNS NXDOMAIN Query | DNS query. Queried domain name does not exist. | Yes |
| DNS OTHER Query | UDP DNS query, DNS Qtype is OTHER, VLAN is <tunable>. To tune this value, in tmsh: modify sys db dos.dnsvlan value``, where value is 0-4094. |
Yes |
| DNS Oversize | Detects oversized DNS headers. To tune this value, in tmsh: modify sys db dos.maxdnssize value``, where value is 256-8192. |
Yes |
| DNS PTR Query | UDP DNS query, DNS Qtype is PTR, VLAN is <tunable>. To tune this value, in tmsh: modify sys db dos.dnsvlan value``, where value is 0-4094. |
Yes |
| DNS Question Items != 1 | DNS Query, DNS Qtype is ANY_QRY, the DNS query has more than one question. | Yes |
| DNS Response Flood | UDP DNS Port=53, packet and DNS header flags bit 15 is 1 (response), VLAN is <tunable>. To tune this value, in tmsh: modify sys db dos.dnsvlan value``, where value is 0-4094. |
Yes |
| DNS SOA Query | UDP packet, DNS Qtype is SOA_QRY, VLAN is <tunable>. To tune this value, in tmsh: modify sys db dos.dnsvlan value``, where value is 0-4094. |
Yes |
| DNS SRV Query | UDP packet, DNS Qtype is SRV, VLAN is <tunable>. To tune this value, in tmsh: modify sys db dos.dnsvlan value``, where value is 0-4094. |
Yes |
| DNS TXT Query | UDP packet, DNS Qtype is TXT, VLAN is <tunable>. To tune this value, in tmsh: modify sys db dos.dnsvlan value``, where value is 0-4094. |
Yes |
| SIP ACK Method | SIP ACK packets | Yes |
| SIP BYE Method | SIP BYE packets | Yes |
| SIP CANCEL Method | SIP CANCEL packets | Yes |
| SIP INVITE Method | SIP INVITE packets | Yes |
| SIP Malformed | Malformed SIP packets | Yes |
| SIP MESSAGE Method | SIP MESSAGE packets | Yes |
| SIP NOTIFY Method | SIP NOTIFY packets | Yes |
| SIP OPTIONS Method | SIP NOTIFY packets | Yes |
| SIP OTHER Method | Other SIP method packets | Yes |
| SIP PRACK Method | SIP PRACK packets | Yes |
| SIP PUBLISH Method | SIP PUBLISH packets | Yes |
| SIP REGISTER Method | SIP REGISTER packets | Yes |
| SIP SUBSCRIBE Method | SIP SUBSCRIBE packets | Yes |
| SIP URI Limit | The SIP URI exceeds the limit. | Yes |
Device Protection is used to protect the entire BIG-IP system. You can configure the AFM system to automatically detect, and mitigate a wide range of DoS/DDoS attacks.
Note: Not all settings apply to all DoS vectors. For example, some vectors cannot use automatic thresholds, and some vectors cannot be automatically blacklisted.
On the Main tab, click Security > DoS Protection > Device Protection.
The DoS Device Protection screen opens.
From the Log Publisher list, select a destination to which the BIG-IP system sends DoS and DDoS log entries.
You can review, create, and update log publishers in System > Logs > Configuration > Log Publishers.
For Threshold Sensitivity, select Low, Medium, or High.
Low means the automatic threshold calculations are less sensitive to changes in traffic and CPU usage. A lower setting causes the system to adjust the thresholds more slowly over time, but will also trigger fewer false positives. If traffic rates are consistent over time, set this to Medium or High because even a small variation in generally consistent traffic could signal an attack. If traffic patterns vary, set this to Low to get fewer false positives.
From the Eviction Policy list, select the eviction policy to apply globally.
Note: The global context requires an eviction policy. If you do not apply a custom eviction policy, the system default policy,
default-eviction-policyis applied and selected in this field. -
Optionally, click the Whitelists area to set whitelists for addresses that can bypass DDoS checks.
To specify a system-wide DoS address list containing Source IP addresses that do not need to be checked for DoS attacks, type the name of a previously configured list in the Whitelist Address List field (see Creating a whitelist address list for details). The system must be at compatibility level 1 or 2.
Note: Available address lists appear on the right side of the screen, in the Shared Objects pane. You can view, edit, and add address lists there.
For Rich Whitelists (all compatibility levels), click the Add Whitelist button, type the name, source VLAN, source or destination address, port, and protocol, then click Done Editing.
You can create up to eight rich whitelists, which allow further delineation of the whitelist.
If the system is compatibility level 2, for Extended Whitelists, click the Add Whitelist button, type the name, source VLAN, source address, destination address, port, and protocol, then click Done Editing.
You can create 256 source and destination whitelist addresses by default and can extend to 1024 by using Extended Whitelists.
At the bottom of the screen, click the Network, DNS, or SIP area to configure detection and mitigation thresholds for a specific attack vector.
The screen displays all the available attack vectors for the given type.
In the Attack Type column, click the name of any attack type to edit the settings.
The attack settings appear in the Properties pane on the right side of the page.
To enforce DoS protection for the attack vector, make sure the State is set to Mitigate (watch, learn, alert, and mitigate).
Other options allow you to Detect Only (collect stats, watch, learn, alert, and no mitigation) or Learn Only (collect stats, watch, learn, and no mitigation).
Note: If you test a legitimate packet with a packet tester and find a DoS vector is preventing packet transmission, you can adjust the thresholds or disable the vector to remedy the issue.
Set the Threshold Mode to Fully Automatic.
- To configure thresholds manually, refer to the next section, Detecting and Mitigating Device DoS/DDoS Attacks Manually.
If the vector includes other settings, such as Bad Actor Detection and Attacked Destination Detection, configure them as needed. If using automatic blacklisting with Bad Actor Detection, be sure to assign a global IP intelligence policy to the device ( Security > Network Firewall > IP Intelligence > Policies).
Click Commit Changes to System to save the changes.
The configuration is updated, and the Device Protection screen opens again.
Repeat the previous steps for any other attack types for which you want to change the configuration.
You have now configured the system to provide custom responses to DoS and DDoS attacks, and to allow such attacks to be identified in system logs and reports.
Device Protection is used to protect the entire BIG-IP system. You can manually configure the AFM system’s detection and mitigation thresholds for a wide range of DoS and DDoS attacks.
Note: Not all settings apply to all DoS vectors. For example, some vectors cannot be automatically blacklisted.
To specify a system-wide DoS address list containing source IP addresses that do not need to be checked for DoS attacks, type the name of a previously configured list in the Whitelist Address List field (see Creating a whitelist address list for details). The system must be at compatibility level 1 or 2.
For Rich Whitelists (all compatibility levels), click the Add Whitelist button, type the name, source VLAN with VLAN mask, source or destination address (with prefix), port, and protocol, then click Done Editing.
You can define up to eight rich whitelists.
If the system is compatibility level 2, for Extended Whitelists, click the Add Whitelist button, type the name, source VLAN with VLAN mask, source address (with prefix), destination address (with prefix), port, and protocol, then click Done Editing.
Extended whitelists can include both the source and destination addresses, and you can create 256 of them, by default. (The maximum number can be extended to 1024, if needed.)
In the Attack Type column, click the name of an attack type to edit the settings.
The attack settings appear the Properties pane on the right side of the page.
Note: If you test a legitimate packet with the packet tester and find a DoS vector is preventing packet transmission, you can adjust the thresholds or disable the vector to remedy the issue.
For Threshold Mode, select Fully Manual or Manual Detection / Auto Mitigation.
Note: When calculating the Event Per Second (EPS) value, the value is applied to a single Traffic Management Microkernel (TMM). Ensure that you multiply the EPS value by the number of TMMs your device has. Two exceptions are the Single Endpoint Sweep and Single Endpoint Flood vectors. The EPS value for these vectors are not multiplied by the number of TMMs.
From the Detection Threshold EPS list, select Specify or Infinite.
- Use Specify to set a value (in events per second) for the attack detection threshold. If packets of the specified types cross the threshold, an attack is logged and reported. The system continues to check every second, and registers an attack as long as the threshold is exceeded.
- Use Infinite to set no value for the threshold. This specifies that this type of attack is not logged or reported based on this threshold.
From the Detection Threshold % list, select Specify or Infinite.
- Use Specify to set a value (in percentage of traffic) for the attack detection threshold. If packets of the specified types cross the percentage threshold of 1-hour average, an attack is logged and reported. The system continues to check every second and registers an attack as long as the threshold is exceeded.
From the Mitigation Threshold EPS list, select Specify or Infinite.
- Use Specify to set a value (in events per second), which cannot be exceeded. If the number of events of this type exceeds the threshold, excess events are dropped until the rate no longer exceeds the threshold.
- Use Infinite to set no value for the threshold. This specifies that this type of attack is not rate-limited.
To log traffic that the system identifies as a DoS attack according to the automatic thresholds, enable Simulate Auto Threshold.
Note: This setting applies only to vectors that can be configured for automatic thresholds. It allows you to see the results of automatic thresholds on the selected DoS vector without actually affecting traffic. When you enable this setting, the current system-computed thresholds for automatic thresholds are displayed for this vector. Automatic thresholds are not applied to packets unless the Threshold Mode is changed for the vector.
To detect IP address sources from which possible attacks originate, enable Bad Actor Detection.
Note: Bad Actor Detection is not available for every vector.
In the Per Source IP Detection Threshold EPS field, specify the number of events of this type per second from one IP address that identifies the IP source as a bad actor, for purposes of attack detection and logging.
In the Per Source IP Mitigation Threshold EPS field, specify the number of events of this type per second from one IP address, above which rate limiting or leak limiting occurs.
To automatically blacklist bad actor IP addresses, select Add Source Address to Category.
Important: For this to work, you need to assign an IP Intelligence policy to the appropriate context (device, virtual server, or route domain). For the device, assign a global policy: Security > Network Firewall > IP Intelligence > Policies. For the virtual server or route domain, assign the IP Intelligence policy on the Security tab.
From the Category Name list, select a black list category to apply to automatically blacklisted addresses.
Specify the Sustained Attack Detection Time, in seconds, after which an IP address is blacklisted.
To change the duration for which the address is blacklisted, specify the duration in seconds in the Category Duration Time field. The default duration for an automatically blacklisted item is 4 hours (
14400seconds).After this time period, the IP address is removed from the blacklist.
To allow IP source blacklist entries to be advertised to edge routers so they will null route their traffic, select Allow External Advertisement.
Note: To advertise to edge routers, you must configure a Blacklist Publisher and Publisher Profile at Security > Options > External Redirection > Blacklist Publisher.
To set thresholds for attacked destinations, select Attacked Destination Detection.
In the Per Destination IP Detection Threshold EPS field, specify the number of events per second from one IP address that identifies the IP destination as an Attacked destination, for purposes of attack detection and logging.
In the Per Destination IP Mitigation Threshold EPS field, specify the number of events per second headed to one IP address, above which rate limiting occurs.
To automatically blacklist bad actor IP addresses, select Add Destination Address to Category.
For DoS protection, the blacklist category is set to denial_of_service automatically.
To set the duration the destination address remains blacklisted, specify the Category Duration Time in seconds. The default is
900seconds. -
To allow destination IP blacklist entries to be advertised to edge routers so they will null route their traffic, select Allow External Advertisement.
Click the Commit Changes to System button at the top of the page.
Repeat the previous steps for any other attack types for which you want to manually configure thresholds.
Now you have configured the system to provide custom responses to possible DoS and DDoS attacks, and to allow such attacks to be identified in system logs and reports, rate-limited, and blacklisted when specified.
You can modify the State and Threshold Mode of multiple attack vectors protecting the device at one time.
On the Main tab, click Security > Dos Protection > Device Protection.
Click the Network, DNS, or SIP area at the bottom of the page.
All of the attack vectors for that familiy appear in the Attack Type list.
To modify the state of one or more attack vectors, click the check box next to each attack vector name.
From the Set State list at the bottom of the page, select Disable, Learn Only, Mitigate, Detect Only, or Mitigate.
Click Commit Changes to System at the top of the page.
To modify the threshold mode of one or more attack vectors, click the check box next to each attack vector name.
From the Set Threshold Mode list at the bottom of the page, select Fully Automatic, Manual Detection / Auto Mitigation, or Manual.
Note: To work accurately, using fully-automatic thresholds requires some amount of historical data on the system gathered through observing normal traffic. Therefore, it is recommended that you not enforce auto thresholds directly after installation.
You have modified the attack vector State and Threshold Mode of multiple attack vectors.
