Applies To:
BIG-IP FPS
21.0.0, 17.5.1, 17.5.0, 17.1.3, 17.1.2, 17.1.1, 17.1.0, 17.0.0, 16.1.6, 16.1.5, 16.1.4, 16.1.3, 16.1.2, 16.1.1, 16.1.0, 16.0.1, 16.0.0, 15.1.9, 15.1.8, 15.1.7, 15.1.6, 15.1.5, 15.1.4, 15.1.3, 15.1.2, 15.1.0
Enable an iRule to handle logins and alerts
Enabling iRules® to handle logins and alerts is only relevant if you have written an iRule to handle the ANTIFRAUD_ALERT event, or the ANTIFRAUD_LOGIN event and the iRule is associated with the same virtual server as your profile.
Enable an iRule to handle logins and alerts if you want to use an iRule to disable alerts or record login events.
On the Main tab, click Security > Fraud Protection Service > Anti-Fraud Profiles.
The Anti-Fraud Profiles screen opens.
From the list of profiles, select the relevant profile.
The Anti-Fraud Profile Properties screen opens.
In the General Settings area of the Anti-Fraud Profile Properties screen, click Advanced.
The Advanced settings appear.
In the Trigger iRule Events setting, select the Enabled check box.
Click Save.
iRules are now enabled to handle logins and alerts.
- iRule events
iRules® can subscribe to theANTIFRAUD_ALERTevent and theANTIFRAUD_LOGINevent in Fraud Protection Service (FPS).
