Updated Date: 07/07/2026
Form element settings - Standard
You can customize the appearance of elements in the logon form using these settings in the General Customization view if you created an access policy or per-request policy with the Customization Type set to Standard.
| Name | Description |
| Field alignment | Alignment of the fields against the form. |
| Field width (%) | Width of the input, password, and select fields as a percentage of the form width. |
| Header alignment | Alignment of the header in the form. |
| Label alignment | Alignment of labels to the corresponding input fields. |
| Label position | Position of field labels: above or to the left of their respective fields. |
| Label width (%) | Specifies a uniform width for field labels as a percentage of the form width. |
