Updated Date: 07/07/2026
Overview: SSL Orchestrator High Availability Diagnostics and Sync-Repair Tool
The ha-sync script is a tool for diagnosing and repairing BIG-IP REST Framework HA synchronization issues between trusted BIG-IP devices.
Note: The SSL Orchestrator HA diagnostics and sync-repair tool and script may be used in other BIG-IP environments to troubleshoot and fix HA setup issues and repair REST framework synchronization issues.
SSL Orchestrator users with an HA setup may also use this ha-sync script to troubleshoot and fix HA setup issues, such as when gossip has gone out of sync, when some REST blocks are missing/out of sync, or even when MCP data is out of sync between devices.
The ha-sync script includes the diagnostic capability to identify potential issues and can print out all of the issues found with the HA setup. The ha-sync script can then perform a sync-up, which should fix those issues, and ensure that both devices are fully in sync (both in MCP and REST).
Note: Due to varying user scenarios, all scenarios have not been tested with the ha-sync script.
Note: In SSL Orchestrator deployments, where a service has been created, you may need to manually create non-syncable network objects if they are missing on the peer device before using the ha-sync script. These network objects include VLANs, non-floating IPs, and route domains created for the service.
This document provides the details SSL Orchestrator users can leverage the ha-sync script.
HA synchronization procedure:
- Review prerequisites
- Revert the effect of ssh-copy-id and removing the passwordless SSH access (optional)
- Use the HA synchronization CLI procedure
- Use the diagnostics capability
- Perform local-only repairs
- Support HA data synchronization for BIG-IP frameworks
- MCP
- REST Framework
Prerequisites
Before upgrading the network for high availability, make sure these prerequisites are in place:
- The
ha-syncscript requires passwordless SSH access from the local BIG-IP device, where the script runs, to the remote BIG-IP HA peer. See the Reverting the effect of ssh-copy-id and removing the passwordless SSH access section below for the procedural steps. This can also be set up by following the instructions in K13454: Configuring SSH public key authentication on BIG-IP systems (11.x - 15.x).-
The following is a summary (procedure) of the aforementioned article. Run the following commands on the BIG-IP device where the
ha-syncscript would be executed. (Replace$HA_PEERwith the IP address of the remote HA peer device).ssh-keygen ssh-copy-id -i ~/.ssh/id_rsa.pub $(whoami)@$HA_PEER
The user account ($(whoami)) should have superuser privileges on the remote BIG-IP HA peer device.
The ha-sync script requires passwordless SSH access from the local BIG-IP device, where the script runs, to the remote BIG-IP HA peer.
Optionally, you may use the following procedure to revert the effect of ssh-copy-id and remove the passwordless SSH access. This can also be set up by following the instructions in K13454: Configuring SSH public key authentication on BIG-IP systems (11.x - 15.x).
SSH into the BIG-IP device where ssh-copy-id has been invoked.
Identify the public key used with ssh-copy-id:
cat ~/.ssh/id_rsa.pub. -
SSH into the remote HA peer (where the related key has been copied).
Edit the /root/.ssh/authorized_keys file and remove the line containing the key retrieved in step 2.
