Updated Date: 07/07/2026
Using the HA synchronization CLI procedure
Below is the usage for the ha-sync script:
# ./ha-sync -h
BIG-IP HA sync repair helper
Usage: ha-sync [OPTIONS]...
-d, --dryrun Dry-run (simulation) mode
-D, --devicegroup NAME Specifies the HA device group name. Default: HA_GROUP
--diagnostic Runs a diagnostic and attempts to detect possible HA sync problems
-f, --force Enforces a more coercive HA sync (see README for details)
-h, --help Displays help text
-H, --host HA_PEER Specifies the HA sync peer
-l, --localonly Attempts a local repair only, without touching the remote HA peer
-m, --manual Manual (step-by-step) mode
-t, --target [NAMES]... Specifies the HA sync target(s) [ALL MCP REST]. Default: ALL
-v, --verbose Provides additional (debug) information
-V, --version Displays the current version of this script
Examples:
ha-sync -H 10.192.228.78
ha-sync -H 10.192.228.78 -d -m
ha-sync -H 10.192.228.78 -d -m -f -t mcpThe following is an example of running the ha-sync script:
./ha-sync -H $HA_PEERThe $HA_PEER should point or be replaced with the IP address of the remote BIG-IP HA peer device. This command should perform the required HA-sync initialization of the REST framework, on both BIG-IP HA peer devices, local and remote.
The ha-sync CLI options and their description:
| Options | Description |
-d, --dryrun |
Simulation mode: displays the internal commands without actually running them. |
-D, --devicegroup |
Specifies the HA device group name. Default: HA_GROUP. |
--diagnostic |
Runs a diagnostic and attempts to detect possible HA sync problems. |
-h, --help |
Displays help text. |
-H, --host |
Specifies the remote HA sync peer (_required parameter_). |
-f, --force |
Enforces a more coercive HA sync (e.g. a full vs. incremental sync). See related details in the Frameworks section. |
-l, --localonly |
Attempts a local repair only, without touching the remote HA peer. |
-m, --manual |
Manual (step-by-step) mode: each command is followed by a Press any key to continue… prompt, before proceeding with the next command. |
-t, --target |
Specifies the HA sync target(s) (ALL, MCP, REST). Default: ALL. Multiple HA sync targets are supported. The targets are sync’ed in the order specified. |
-v, --verbose |
Provides detailed debug information. |
-V, --version |
Displays the current version of the ha-sync script. |
The following is an example of a verbose, manual, and dryrun invocation of the ha-sync script (sample output shown):
./ha-sync -H 10.192.228.78 -d -m -v
debug: check_env(): Checking passwordless SSH access to remote HA peer 10.192.228.78...
debug: check_env(): Successful passwordless SSH access to remote HA peer 10.192.228.78!
info: Starting MCP HA sync...
info: Initiating CM Config-Sync locally...
tmsh run cm config-sync to-group HA_GROUP
Press any key to continue...
info: MCP HA sync completed!
info: Starting REST Framework HA sync...
info: Stopping restjavad locally...
bigstart stop restjavad
info: Stopping restjavad on 10.192.228.78...
ssh -o BatchMode=yes 10.192.228.78 bigstart stop restjavad
info: Removing REST Framework storage on 10.192.228.78...
ssh -o BatchMode=yes 10.192.228.78 rm -rf /var/config/rest/storage
...The advantage of a manual and step-by-step run is that the user can copy/paste and invoke the commands at will, while also testing the results, etc.
Below is an example of using the diagnostics capability of the ha-sync script:
ha-sync --diagnostic -H 10.192.28.52
info: Retrieving platform versions locally...
info: Retrieving platform versions on remote HA peer [10.192.28.52]...
info: Starting MCP diagnostic...
info: Starting REST framework diagnostic...
info: Retrieving device/machine IDs locally...
info: Retrieving device/machine IDs on remote HA peer [10.192.28.52]...
info: Checking REST framework device groups locally...
info: Checking REST framework device groups on remote HA peer [10.192.28.52]
info: No problems detected!The ha-sync script can be invoked with the --localonly (or -l) option parameter to exclusively attempt a local repair of the REST framework, without touching the remote HA peer:
./ha-sync -lNote: The ha-sync script is idempotent in terms of yielding consistent results with successive runs.
