Manual Chapter : Form element settings - Standard
Applies To:
  • BIG-IP APM
    21.0.0, 17.5.1, 17.5.0, 17.1.3, 17.1.2, 17.1.1, 17.1.0, 17.0.0, 16.1.6, 16.1.5, 16.1.4, 16.1.3, 16.1.2, 16.1.1, 16.1.0
You can customize the appearance of elements in the logon form using these settings in the General Customization view if you created an access policy or per-request policy with the Customization Type set to Standard.
Name Description
Field alignment Alignment of the fields against the form.
Field width (%) Width of the input, password, and select fields as a percentage of the form width.
Header alignment Alignment of the header in the form.
Label alignment Alignment of labels to the corresponding input fields.
Label position Position of field labels: above or to the left of their respective fields.
Label width (%) Specifies a uniform width for field labels as a percentage of the form width.
